tommu56
Elite Member
Unfortunately there is no standard on the QD's you have to stick to one brand to be assured they will work.
I'm glad you got it figured out.
tom
tom
Did you use 1/4 in. rather than say 3/8 in. lines in order to reduce the speed?
But I have a hard time understanding what those "springs" in the Quick Couplers have to do with anything. Those springs are made to prevent leaking when UN-coupled....not during operation.....no?
Looks good.....but just a word of caution.....
If ya hit something while plowing, you're likely to blow a cyl or hose (or worse damage to tractor frame) if a cushion valve is not installed inline between tractor valve and cyls......the plow manufacturers incorporate these pressure controls in the main plow valve
https://www.surpluscenter.com/item.asp?item=9-4019-50-H&catname=hydraulic
The idea is for the cyl to by-pass instead of doing harm to your equipment when hitting hidden obstacles......
I used 1/4" because that is the way JD set's up the hardlines kit alongside the loader. The couplers they furnish are 1/4" Pioneer Brand QD's.....and so I got two more sets to attach my grapple and FEL Snow Plow. Never an issue. Also.....yes I did read where the 1/4" lines will slow the grapple cylinder to help with operation.....I like the speed I get.
