Attachment GPM requirements VS. Tractor GPM output
   / Attachment GPM requirements VS. Tractor GPM output #1
jc7622
Edmond, Oklahoma
Montana 5740C
I came across a used post driver that supposedly requires about 12GPM. My tractor manual (Montana 5740) says that it puts out about 8GPM. Will I have to pass on the post driver or can something be done to increase my tractor's hydraulic GPMs?
   / Attachment GPM requirements VS. Tractor GPM output #2
Nothing you can do to increase your output short of a new/larger displacement pump. You could use a PTO pump. Whether or not the implement will work at a lower volume is a different story. I don't know about post drivers but most hydraulic cylinders will work at lower flow, will just be very slow /forums/images/graemlins/smile.gif
   / Attachment GPM requirements VS. Tractor GPM output #3
If it is the hydraulic up and spring wham down type it should work , will just go up slower.
Ben
2097 (A49339)
2097 (A49339)
(6) Front Tractor Weights (A49339)
(6) Front Tractor...
90in. Work Bench (A46502)
90in. Work Bench...
Skid Steer Trailer Mover (A49339)
Skid Steer Trailer...
2003 Lexus LS 430 Sedan (A46684)
2003 Lexus LS 430...
2013 Ford Escape (A46684)
2013 Ford Escape...
