Attachment GPM requirements VS. Tractor GPM output
   / Attachment GPM requirements VS. Tractor GPM output #1
jc7622
Edmond, Oklahoma
Montana 5740C
I came across a used post driver that supposedly requires about 12GPM. My tractor manual (Montana 5740) says that it puts out about 8GPM. Will I have to pass on the post driver or can something be done to increase my tractor's hydraulic GPMs?
   / Attachment GPM requirements VS. Tractor GPM output #2
Nothing you can do to increase your output short of a new/larger displacement pump. You could use a PTO pump. Whether or not the implement will work at a lower volume is a different story. I don't know about post drivers but most hydraulic cylinders will work at lower flow, will just be very slow /forums/images/graemlins/smile.gif
   / Attachment GPM requirements VS. Tractor GPM output #3
If it is the hydraulic up and spring wham down type it should work , will just go up slower.
Ben
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2015 Ford Expedition EL SUV (A51694)
2015 Ford...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
