NY_Yankees_Fan
Veteran Member
- Joined
- Mar 4, 2002
- Messages
- 2,209
- Tractor
- Kubota BX 2200
Thanks guys, love the knowledge here, very much appreciated.
There really is no way to cool an attic other then encapsulating it and running cool air into that area. Venting is not for cooling. No amount of air flow in an attic is going to lower the air temperature up there. Venting is designed to keep the framing dry. Attics without proper venting have condensation, which leads to mold, rot and shingle failure. Adding a fan might increase air flow, depending on it's location, but it will never lower the temperature. It's one of those things people sell because people will spend money on it hoping it will do something when it doesn't.
Eddie
Correct.I'll agree that limiting moisture is the most critical benefit of venting, but while venting won't "cool" the attic, it will significantly limit the heat increase.
IF your feeling the heat in the ceiling from your attic, putting a 8-12" layer of insulation in over what you have now would likely pay for the cost in electric for heating AND cooling in a year, 2 at most. When we built our retirement home we put the solar radiating plywood in on the roof and walls, put in 8" bats in the walls, R52 in the ceiling, double pane glass in all the windows and doors. The AC rarely comes on even in 100F heat and then only runs a few minutes. We have a total electric home (2308 sq feet heated area) and electric runs about $150 per month average year round.Correct.
Last year or the year before I finally got around to installing a thermostatically-controlled power gable vent I had sitting around for 10 years.
Makes a very significant difference on the heat gain in the house - particularly on really hot, sunny days.
Before, the AC could not keep up ... and I could feel heat radiating from the ceiling ... now, it's able to maintain the temp set on the thermostat (usually 72F to 74F) throughout the entire day.
How does moving the air cool the air? It just changes the location of the air. Don't confuse what a fan does on your skin to what it does to the air itself.
Eddie
Eddie
