Auger questions
   / Auger questions #1
Davinator
Southern Ohio
Kubota #M6040 w/Grand Cab
I will be buying a new auger for my Kubota #M6040 in the spring of the year. I thought the choices/selection would be minimal but a friend recommended that I seriously consider buying a skid steer auger instead of the basic 3PH model. (It should be noted that I DO have the additional hydraulic lines installed on my FEL for a grapple). His reasoning is that, based on his experience, in digging holes in our area, where there are lots of rocks in the ground, it is a normal thing for the auger to get stuck and have to be unhooked and removed with a pipe wrench. Also, with the minimal down pressure, there will be a lot of hand work with a spud bar on each and every hole.
His reasoning makes sense to me, but I wanted to get some more input before making the final decision. (In looking a the specs from my tractor, I have a max. hydraulic flow of 11GPM.)
Any advice/viewpoints will be appreciated.
   / Auger questions #2
I use a McMillan on my M8540 like you are talking about. It is great in hard / tough soil. The only issue I have run into is that it turns to slow in soft soil and doesn't self clean well.
The big advantages I see are having it offset to one side it's easy to see. The other is no more broken sheer pins.
E/S
   / Auger questions #3
You may want to price a Belltec auger, you wont be able to beat one of them in tough soil.
I've drilled 100's of holes with a 3pt and never really had a problem getting stuck in rock, maybe 5%. Shear bolts are another thing, but I'd rather loose a $2 bolt than a gear. I just watch my down pressure.
If money isn't an issue and you want the best, go Belltec.
Drill holes fast with Belltec products -- Belltec Industries, Inc.
2004 BOBCAT 331G EXCAVATOR (A52707)
2004 BOBCAT 331G...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
2014 Chevrolet Silverado 3500 HD Reading Service Truck (A55852)
2014 Chevrolet...
