auto-darkening welding helmet
   / auto-darkening welding helmet #21
Hello to the welding "experts" and I use that term advisedly /w3tcompact/icons/grin.gif 'cause I know you're out there.
I am an aspiring welder with, as yet , no welding equipment (my very experienced buddy who has all the toys -except the auto darkening helmet- has agreed to teach me some technique as we embark on the building of a CADDIGGER 821 backhoe) and I have been following a few of the threads here with more than passing interest.
In Canada, a company called <A target="_blank" HREF=http://www.princessauto.com>Princess Auto </A> sends out a monthly flyer and, in the one I received last night, they advertised a "Variable Shade, Auto Darkening Welding Helmet" with the following features:
- darkens in 1/25,000 of a second at room temp
- solar powered
- rugged, lightweight construction
- large 3 7/8 by 1 3/8 viewing area
- adjusts from shade #9 to # 13
- variable shade lens switch located on exterior for easy adjustment
- Wt - 4 lbs
Reg - $329.99 SALE $222.22
Note the prices are CDN$ - so for you guys in the USofA that's probably less than a buck and a half /w3tcompact/icons/tongue.gif
The flyer says Made in Italy but does not provide a manufacturer name
Does this sound like it is worth checking further?
If so I would really appreciate any comments on what additional question I should be asking and feartures I should be insisting upon.
Also, any comments on the pros and cons of solar vs battery operated would be helpful. Could this be the photo cell charging the wroughtn_harv referred to earlier in the string?
Douro Bob
   / auto-darkening welding helmet #22
I'm a novice welder and found that the auto darkening helmet made the task a lot easier. I got mine from Harbor Freight for $99.00 and it is solar. I've used it for the last year with no problem.
John Deere CP24E (A53317)
John Deere CP24E...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
2023 Kubota L6060HST Compact Utility Tractor (A55315)
2023 Kubota...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
UNUSED PABREAK DB220-84" HYD DOZER BLADE (A57193)
UNUSED PABREAK...
UNUSED PABREAK METAL BUCK SHOOTING TARGET (A57193)
UNUSED PABREAK...
