Auto reset reactive steel targets
   / Auto reset reactive steel targets
The large AR500 plate target works like this.
Pressed over bar stock bored and illite bushing installed there is a spring between it at the shaft the target pivots on and a bolt shank that comes up from the bottom.
The cam forces the motor/drive towards the target up to the point it is reset then let's the spring push it back of the "dog""
This one is an old video but you can see what is going on.
Here you can see the bold shank that comes up from the bottom that the cam rides on (grade 8 bolt cut off).
Motor torque is transferred to the plate below and oillite rollers are on the motor bracket. One switch is closed all the time except it opens when the "reset" tab is just shy of contacting the "target" tab. The other switch is open except when the target is hit and falls.
It generally resets a lot faster because it is actually a 24v DC motor but as you can see from the video it will work off of 12v of your not in a hurry.
The deer feeder batteries are in feeders this time of year but I installed power ports in the rear when I built it so it could be powered remotely (you can see the battery to the right of my bullet trap).
The plate racks are much more simple, just not as compact. They use a power window motor from an old car and a gear. A seasoned junk collector with notice that the nearest gear is actually a Chevorlet flex plate.
At the bottom of the stroke the connecting rod to the reset arm above, opens a normally closed limit switch.
When the last target falls it hits a momentary switch powering the motor long enough to be off the limit switch so it can make another revolution, resetting all of the plates.
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
2016 Dodge Charger SRT Hellcat Sedan (A53424)
2016 Dodge Charger...
2015 DODGE RAM...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A54757)
UNUSED WOLVERINE...
