AutoHitch???
   / AutoHitch??? #11
Correct, The imatch will fit almost all 3ph attachments as long as you have a set of bushings for them that you can get from JD. When I purchased my set-up they threw in the bushings for all my attachments.
The auto-hitch is pretty limited on the attachments it will fit, and in my opinion is a novelty item. So in conclusion, imatch=yes & autohitch=nah :)
FYI: You can get the bushings at various places like TSC, or online: QUICK HITCH ADAPTER KIT CAT 1-3
   / AutoHitch??? #12
Unless you are physically unable to lift 20lbs then hooking the PTO up is fairly easy.
   / AutoHitch???
seems to me with only 2 implements being suitable for the auto hitch that it is going to take longer removing the pto so as to use just the quick hitch.
   / AutoHitch??? #14
I got the quick hitch with my 2520 because I didn't initially have any rear PTO attachments, but did have a rear blade and I wanted to use it to pick up the 62D deck. I'm wanting a post hole digger, but I have to take the quick hitch off anyway to attach any PHD, so neither quick hitch or auto hitch real are of any use for that kind of implement. I'd save your money and put it toward other accessories.
   / AutoHitch??? #15
FYI... the "iMatch" is nothing but a fancy name for a 3pt quick hitch. You can buy that same adapter from dozens of sources. I got one at Harbor freight once for $69.
2017 HINO 268 BOX TRUCK (A54607)
2017 HINO 268 BOX...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2017 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2015 FREIGHTLINER...
2019 Dodge Durango (A53421)
2019 Dodge Durango...
