Automatic Float Valves for Livestock Watering
   / Automatic Float Valves for Livestock Watering #11
They make some large diameter PVC with smal diameter clean outs.. say.. 2" then just get a 2" to ? 3/4 bushing.. etc.
Soundguy
   / Automatic Float Valves for Livestock Watering #12
Well, I use the standard stock brass float valve... it has a long arm with round plastic ball on the end. My modification is to have the supply pipe and valve way under water very near the bottom of the trough... I attach a piece of light chain to the threaded long arm and use a bolt/screw thru the chain to attach the plastic ball float. This forms a flexible connection between the float and the valve. Make sure it swings free. Adjust the chain length to suit. I have found this to be a reasonable arrangement. It allows the cattle to mess with it and not break anything. I've had this installed until the chain rusted thru and needed replacement. Nothing is perfect:rolleyes:
   / Automatic Float Valves for Livestock Watering #13
Gary, Delta makes a valve that I've used in Boerne in our hard water for about 5 years they are in the toilet tanks but there is no reason that you couldn't use them in the bottom of your stock tanks it is a disc about 4" across and takes the place of all the floats and chains and such its cheap like less then $10 and has lasted well for our hard water. The good thing for you is its in the absolute bottom and just senses the water pressure and turns on and off accordingly. I'll have to admit that I've gone the lazy route on all my livestock stanks and just use the aluminum one from TSC but I'm raising equines and they aren't near as hard on stuff as a cow usually unless it looks like a toy and then they will play with it or carry it miles from the house before they drop it hitting each other with it the whole way they usually do this with the rubber feed bowls even the ones that are 2 or 3 feet across and 18" deep. I probably own 20 of them so I can wait until I'm on the last couple before getting to serious about gathering them up and starting the cycle over again. I copied this ad of the web to give you an idea of what it looks like its called a Delta Fill Pro
more info Toilet Ballcock Tank Valve - Delta Fill-Pro
Plumbing - Ballcocks - Toilet - Self-Contained Ballcocks
Item: 9389 ... Delta Fill-Pro Tank Valve
Price: $8.98
Check Volume Discounts
Steve
That sounds like a good setup. Do you have your piping entering the taknk from the top or through the tank somehow?
I've used the big o-ring connectors on my spray tanks and it occurs to me that you could mount one of those in the tank floor. In my case, it's a 6' tank, so if you put it in the middle, the float ball on a chain would be hard for the cows to reach. Even better, the valve and supply piping would be protected during freezes. The top of the tank may freeze, but not in the middle bottom of the tank.
   / Automatic Float Valves for Livestock Watering #15
I'm glad my horses are not the only ones that pull shenanigans like that..
I never know where my rubber feed bowls will end up...
Soundguy
Steve
   / Automatic Float Valves for Livestock Watering #16
I don't mind the feed bowls so much its other stuff like your working on your chisel plow putting on shovel points and you look up as one of them is running across the field with the bag of new plow bolts firmly clinched between their teeth that the real battle begins. Good to know I'm not the only one that has equines with a good sense of humor.
Steve
   / Automatic Float Valves for Livestock Watering #17
I've actually had my horses accidentally kill a chicken before. I was transfering a rooster from one pen to another ( too many roosters in one pen makes for quite an issue.. ) and I had the rooster in a small pet carrier. in the back of my CUV.. had to go inside to make a phone call.. came back out an dthe horses were throwing the pet carrier around in the field... poor bird was dead by the time I got to him... musta had a heart attack...
That's the kind of mischief that my nags get into...
I remember one day my horse got his halter hung on a gate latch and pulled back, popping the latch clean off. ( and staying attached to his halter... ) the gate was to a little 8x8 3 board fenced area around a well pump/tank in the pasture. The horse then proceded to eat the succulent grass in that area, and squeezed himself around the corner and then got himself stuck between the fence and the (expensive) pump and tank. Couldn't go forward due to the plumbing... couldn't go back due to the extreme angle he would have to back up.. I came home from work and about had a stroke when i saw that. I ended up having to pop the fence boards off ont he side and keep him calm while doing it. then move the boards so he didn't trip on them while exiting... Cost me an hour of work for that deal... At least i didn't loose the pressure tank... thought for sure I was going to!
Soundguy
   / Automatic Float Valves for Livestock Watering #18
GaryBDavis ,
I answered your question last night... but somehow the response seems to have gotten lost... let me try again.
Water line comes into the wall of the metal tank near the bottom... it is really intended to be a drain plug. Gotta take a metal pipe, add about 6 inches of threads to it, screw this pipe from outside into the tank.... several inches stick out inside and are threaded sufficiently to attach other components as needed to get the valve, arm, chain and float connected at right height.
Being near to ground, if you cover the input pipe then it is less prone to freezing, as you surmise... have had trough ice over ... remove top ice and water begins to flow when the ball again is floating, although shrouded in ice.
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55301)
2017 KINZE...
2014 Ford F-550 4x4 Crew-Cab Flatbed (A52377)
2014 Ford F-550...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
2001 John Deere M665 (A50120)
2001 John Deere...
2005 FORD F350 XLT SUPER DUTY SERVICE TRUCK (A51406)
2005 FORD F350 XLT...
