Aux Valve For 2630 and 3030
   / Aux Valve For 2630 and 3030 #1
Devildog
Platinum Member
Luray, VA
Kubota B2630
I was just checking to see if anyone had this option on there tractor. I was thinking about getting this installed to use for TNT. Is there a package# for this? It would be nice having the control handles mounted right behind the 3 point and cruise control. Also anyone know the cost for this option? Thanks, Jim
   / Aux Valve For 2630 and 3030 #2
Here's a link (a PDF file) for the part numbers. You must have Acrobat Reader to open it.
B3030 part numbers
Look at pages 312 to 323 (Acrobat Reader) or 154 to 159 (PDF file). You'll have all the part numbers you need.
It cost me around 800$USD for two valves (no float because I already have an outlet for the backhoe). The float thing is: you have a choice to make whether you want your first valve with float or not. Must of the guys here on TBN will tell you to go with float. I didn't because I have a rear outlet for my backhoe so I can use that outlet for a log splitter for instance (the log splitter comes with a valve to operate it but you need a constant hydraulic flow... that's why the float option).
Here are two pics of my installation. I'll add those pics to my tread "candies for B3030".
   / Aux Valve For 2630 and 3030 #3
The other one.
Stef,
Thank You my friend. There are not any tractors in my area to compare this to. The pics are a real big help. I also have the backhoe so Im like you about the float. I will check with the dealer. I know they have to have a single part# for a kit. I also will check to see how much for everything installed. It will be a little while since we are in transition. I like to have all my ducks in a row before attempting an install by my self /forums/images/graemlins/wink.gif Maybe I can have it done before next spring if I do it myself. Thanks Jim
PAIR OF 5' CLIP ON TRAILER RAMPS (A54756)
PAIR OF 5' CLIP ON...
2018 Ford Fusion Hybrid Sedan (A55758)
2018 Ford Fusion...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2007 INTERNATIONAL 4300 SBA 4X2 DUMP TRUCK (A51406)
2007 INTERNATIONAL...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A55302)
2010 Ford F550...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A54757)
UNUSED WOLVERINE...
