Auxiliary valves and a Top and Tilt install on a L3940HST
   / Auxiliary valves and a Top and Tilt install on a L3940HST #1
rogerius
ON, Canada
Kubota L3940HST
I installed just two valves (one with flow detend) with idea to be used for a top and tilt system. The install of the valves went pretty smooth. Just want to point one small design flaw found during the install: because the valve bracket is wider with almost 1/2" than the existing bracket holder, the 3pth hose is pushed away from initial location and now the hose is quite tensioned; I hope it will not crack or snap from fittings in time.
I was shopping around for a while and compared the prices between US and Canadian dealers. Finally I purchased the valves from a dealer in NY states. The save was almost 400$; still not understand from where is this difference as the $US and $CAD are almost the same, but seems we have hungry dealers here in Canada.
I purchased the Top and Tilt kit from Fit Rite Hydraulics and Brian did a great job in shipping all the staff:thumbsup:. The quality is great and installation was seamless. Took me one afternoon to finish the job and I attached couple pictures. Now, I'm ready to start the 700' driveway.:cool2:
After couple of runs, I see a small leak at one of the quick disconnects so I will keep an eye on it.
The next step is to find a holder for the top cylinder; right now I've got an elastic cord to keep it suspended. Do you have any idea other then keep the box blade attached all the time; a picture will be appreciated?
   / Auxiliary valves and a Top and Tilt install on a L3940HST #2
Congratulations on your rear remotes and TnT. A great tractor usefulness enhancer. You will like your TnT system. Especially for doing road work.
If you find a good way to hold the top cylinder please post it. I use a bungie cord similar to yours and keep thinking there must be a better way.
   / Auxiliary valves and a Top and Tilt install on a L3940HST #3
I bungee my top cylinder too. Would love to find something better...
   / Auxiliary valves and a Top and Tilt install on a L3940HST #4
Nice work. I also bungee mine and am looking for ideas
   / Auxiliary valves and a Top and Tilt install on a L3940HST #5
Very nice looking setup; looks as good as the OEM, I always have something on my 3PH, so I haven't fixed anything up, I think Brian posted something on it one time using the existing holder, but I may have him confused with someone else.
   / Auxiliary valves and a Top and Tilt install on a L3940HST #6
Here is a picture of the holder used on an L4600. It should be easy to fabricate something similar.
  • L4600 912:12:12)2.JPG
   / Auxiliary valves and a Top and Tilt install on a L3940HST #7
When I looked at your picture I could smell a familiar odor...... Oh yeah,,,, new paint and rubber smell!!!! :thumbsup:
   / Auxiliary valves and a Top and Tilt install on a L3940HST #8
A tarp strap works good
A quick hitch works better.
   / Auxiliary valves and a Top and Tilt install on a L3940HST #9
That's Blasphemy Roger!!!! A JD Quick Hitch on a Kubota!!!! :eek:;)
   / Auxiliary valves and a Top and Tilt install on a L3940HST #11
What about a link of chain hose clamped to the cylinder? Positioned in the correct location, I think that you would be able to hook it onto the OEM retainer. ;)
   / Auxiliary valves and a Top and Tilt install on a L3940HST #12
Good idea Brian!!! I'll use this rainy afternoon to play around with that idea and rig up something.
   / Auxiliary valves and a Top and Tilt install on a L3940HST #13
Please post a pic or 2 if this works out. In fact even if it doesn't, then maybe someone can come up with something different that is easy.
2013 Ford F-250 Pickup Truck (A59230)
2013 Ford F-250...
iDrive TDS-2010H...
2014 Freightliner 105' Bucket Truck (A61306)
2014 Freightliner...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
