Avoiding Gate Sag
   / Avoiding Gate Sag #11
1bush2hog said:
Initially I wanted to put in one of the forest service type heavy duty gates, but the cost ended up being more than I wanted to spend. I have a cable attached to two trees and stretched across my road now that keeps most vehicles out - except the renegade atver's.
I noticed when I drove by our local air base that they've added something to the 8' high chain link fence, which already had barbed wire on top.
They've placed a heavy (maybe 1") steel cable about 30" above ground level and secured it to the fence. About every 30 yds, they have a 6x6 steel post anchored in concrete with the cable attached to it.
I'm sure the goal is to keep someone from driving a truck through the fence easily..................
Looks to me like it will work.
ron
   / Avoiding Gate Sag #12
1bush2hog , you are dealing with numerous issues. Bottom line, somebody wishes to mess things up, they will.
I will address the post sagging problem you wish to avoid. To start with, use the strongest posts you can afford and bury them as deep as possible. 4 feet is good. Welded metal pipe posts and H brace near the top of the posts (not centered) is best, my opinion. If you use treated pine, I would NOT use concrete. I have done this and they rot out in a few years. Yes, the ads say something line "30 year ground contact" but, trust me, they rot and are a pain since this is an important fence corner/post. I would get a tamp bar and tamp them into the ground using rocks/gravel which allow water to drain away from the wooden post.
The very best and cheapest tensioning device I have found is to go to TSC and get some high tensile 12.5 gage wire and rachet tensioners. Tensioners are $3.00 or less. Wire is galvanized, withstands lots and lots of pull. I permanently install the rachets and high tensile wire whereever I need a tensioning wire. Then, later, if a post starts comming out of the ground or something gives all you need to do is to retension the wire with the rachet. There is a handle you can get that makes the rachet tightenting procedure very simple.
Best wishes!!
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
Box Truck Hydraulic Tuck-Away Lift Gate (A52377)
Box Truck...
2019 Allmand Bros Maxi-Lite II 15kW Towable Light Tower (A52377)
2019 Allmand Bros...
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
