oldballs
Elite Member
- Joined
- Dec 29, 2009
- Messages
- 4,406
- Location
- Kansas...USA
- Tractor
- Kubota B2620 , Case 448 , Kubota B2650
Okay so I tried the "Search Function". Forget that. In draining the HST filter oil outlet and the Hydraulic filter oil outlet, I get only 2 gallons. The book specifies the capacity as 4 gallons. So I looked for the other elusive drain plugs in the rear end. Let's see??? It looks like most of the bolts are holding the rear end together. Since I own a parts manual, I looked there to see if there is any identification of such. The manual show to likely bolts but calls them "flange bolts"...not drain plugs. Well I loosened one on either side and the oil does drain out. So the job is done. But the Owners Manual sure didn't help me much. Can anybody else confirm my expericence or tell me where I went wrong? Thanks.........Mike........Oh Yeah.......watch out for the little steel ball that is spring loaded on the HST side drain plug.
