B-2620 MMM drop rate
   / B-2620 MMM drop rate #1
ritchieb
near Parkersburg, WV
Yanmar 1610D/Kubota B2620
Good evening all. Just a quick question on the B-2620 60" MMM. I am aware of the adjustment valve for the drop rate on the hydraulics. Since new I have always thought the "up" on my deck was way too fast. I can adjust the drop rate just perfect. My question is can the "up" rate be adjusted also? My deck slams into the stop brackets on the mower suspension. Any way at all to slow the pickup rate down?
Thanks in advance,
Bret
   / B-2620 MMM drop rate #2
Slow the engine RPMs down. My BX will do the same thing if I just yank up on the lever.
   / B-2620 MMM drop rate #3
No, it can't be adjusted. Learn to anticipate it and quicken you lever movement. Idling down when mowing would be very inconvenient. I raise my deck every time I back up. :)
Thanks guys for the responses. I was hoping it could be adjusted or I had overlooked it in the manual. May have to live with that "thump" after all!
Bret
   / B-2620 MMM drop rate #5
I've been living with the same "thump" since new...on my 2012 year B2620. When I asked the dealer about it, he essentially said ..."That's just the way it is". But slowing down the rpm, as others have said, softens the "thump". I also mow with a 60 inch MMM on my B2650, and it only has a little "thump" at any rpm. But the 2650 MMM is a different design.
Thanks for the info fellas. Great to have knowledgeable advice, just thought there might be a way to lessen the "bump" that I was overlooking. Now back to mowing!
   / B-2620 MMM drop rate #7
Another suggestion might be to put a rubber stop on whatever it is hitting. You can get them for cheap at your local hardware store in the hardware section.
2014 Eagle Beaver 50SL/3 24ft Tri-Axle RGN Trailer (A56858)
2014 Eagle Beaver...
2012 CAT 316EL (A55272)
2012 CAT 316EL...
LEINBACH SCOOP PAN (A52708)
LEINBACH SCOOP PAN...
New/Unused Electric Golf Cart (A57453)
New/Unused...
2012 Ford Transit Connect Van, VIN # NM0LS7DN0CT092703 (A57453)
2012 Ford Transit...
John Deere 5100M (A53317)
John Deere 5100M...
