B xx20 series with bar turf tires
   / B xx20 series with bar turf tires #1
gabrichter
Bronze Member
South Dakota
2012 Kubota B2920
the B2920 came in with the 31" bar turfs on rear and different style 22" type turf up front. Dealer offered to put standard turfs on but after looking hesitantly over agreed to leave them on. I will be using it on grass/dirt and snow so covering type of use. Any one out there have these and give me you opinion on typical use and how they performed.
   / B xx20 series with bar turf tires #2
Turfs work better on snow & grass, and they are great on dirt... Most motor graders and heavy equipment, when switched to turf type tread preform better..... But they are not the best in Mud.
KennyV
Just making sure no one confuses the standard turf tire with the bar/turf that is coming on my B2920 they are quite different.
   / B xx20 series with bar turf tires #4
Are the two styles compatible in terms of tire rotation? If it's like using ags in back and turfs in front, probably not such a good idea.
   / B xx20 series with bar turf tires #5
A friend has the bar turfs on the rear of his B2410 and absolutely swears by them. The only disadvantage is he must use a slightly shorter front tire to make axle ratios work and with that, a slight loss in ground clearance.
   / B xx20 series with bar turf tires #6
I have the bar/turfs and have been very satisfied with them.
   / B xx20 series with bar turf tires #7
I'm another satisfied owner of bar/turfs. I searched on this site quite a bit about tires before getting my 2320 and ended up with the bar/turfs.
Sounds like they will be good tire, just don't really like the mismatch of tread on back to front, wish the fronts were similar or close. I am hoping I will not need chains for blowing snow in the winter not cheap at around 230.00 for rears. Overall on turf and dirt they should be exceptional.
   / B xx20 series with bar turf tires #9
Whats a bar turf? Are you refering to the R4 industrial tire?
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
Unused Delta Crash...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
2010 Ford F-150 4x4 Pickup Truck (A51692)
2010 Ford F-150...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2002 CLEMENT END DUMP TRAILER (A52472)
2002 CLEMENT END...
