B1700 to pull 4ft bush hog on hills?
   / B1700 to pull 4ft bush hog on hills? #1
jebw
Hey folks,
I've never owned a tractor, but I'm now shopping around for a small kubota. I've got about 16 hilly acres, and the majority of the land is too steep for our use, other than firewood gathering and hunting deer. About 6 acres of moderate slope is already cleared and I plan on maintaining that 6 and not clearing any more land. I plan on bush hogging about 2-3 acres 1-2 times a year. I've also got about 75 yds of gravel drive to maintain and clear the occasional snow off of. The rest of my cleared land I mow with a ztr which I plan on keeping.
Right now, I'm looking at a b1700 with 1000 hrs on. Comes with a 4ft woods bush hog, 5 foot scraper blade, and a la301 loader for $7500.
My main question is, with 14hp at the pto, is this tractor too small for the bush hog, particularly when hills are involved? I don't mind going slow, but I do want to be able to get the job done. Thanks in advance for the advice.
   / B1700 to pull 4ft bush hog on hills? #2
It's really about how slow you're willing to go and what cutting conditions are. If you find that conditions are too difficult for this combo, you can mow slower or keep part of the mower over the section that you've already completed.
Mike
   / B1700 to pull 4ft bush hog on hills? #3
That B1700 will do the job, but I reckon you'll wish you had a larger tractor within a year.
   / B1700 to pull 4ft bush hog on hills? #4
Is it 4WD? 4WD would be much better and safer on the hills. In 2WD you only have rear brakes. If you have 4WD then the rear brakes also brake the front wheels.
I ran a 5' bushhog on a B21 with 13 PTO HP / 21 HP total. I believe you will want more than 14 HP to bush hog hills with a 4' bushhog.
   / B1700 to pull 4ft bush hog on hills? #5
I run a 42" squealer on the back of my BX23 and that's a good combo...PTO on mine is just less than 17hp.
Don
   / B1700 to pull 4ft bush hog on hills? #6
It can do it- speed will depend on heavy the vegetation is. I mowed two fields, very heavy growth that had not been touched for 3-5 years,( the briars and brambles were over my head in places) for my brother when he first bought his land. The total acreage was about 12 acres, and it took around 18 hours of work with a 4' cutter and a 13 hp tractor.
   / B1700 to pull 4ft bush hog on hills? #7
I had B1700 cousin B7100HST w/4" bush hog and did well.
What type of rear tires..turfs?..if turfs you may want to consider tire chains when mowing slopes.
It is 4WD and it has R4 tires. I can take smaller cuts when mowing so as not to bog down, but I wasn't sure if I should be concerned about the weight of the bush hog when mowing on hills.
   / B1700 to pull 4ft bush hog on hills? #9
With the bush hog in the down position, there should be no problems with the extra weight of the mower back there. However, if you have any intentions of trying to drive up any of those hills with the bush hog raised up (even just a little bit) and the loader unattached, you WILL NEED to add weight to the front end! Best just to always let it ride on the ground when you're driving up/down the hills, even if the PTO is disengaged.
As far as PTO HP for the mower, it should do ok with a 4ft mower long as you match the speed to the height/thickness of what you are cutting. As already mentioned, you can also take smaller swathes on each pass if needed, instead of using the whole 4ft width. There are some 3ft mowers available but I don't think you would want to go that small. Just be careful starting out learning the equipment and do get in the habit of wearing the seat belt everytime you hop on it.
   / B1700 to pull 4ft bush hog on hills? #10
Hey folks,
I mowed with a 4-ft brush hog on the back of my Kubota B7510HST (17 hp pto). No problem. Your B1700 should handle one of these mowers OK.
Just watch out on those "moderate" slopes--SCUTs can be tippy when cutting along slopes, especially if one of the downslope wheels drops into a 6" or deeper depression.
2018 GENIE GTH-844 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-844...
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
Case 950 8 Row Air Planter (A55301)
Case 950 8 Row Air...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
