B21 Tachometer Bouncing
/ B21 Tachometer Bouncing #1
BruceWard
Platinum Member
Central, AR
Above 2500 RPM or so the tachometer starts bouncing around and over reporting. It does not happen at lower rpms and calms down after a while. This started recently after sitting for a few months.
Any ideas?
/ B21 Tachometer Bouncing #2
I rarely run my B21 above 2000 RPM, but sounds like a moisture / electronic issue. The tach is electronic not mechanical from what I recall.
/ B21 Tachometer Bouncing #3
Any ideas?
Check for a bad ground.
Try the battery ground first. Ground the battery directly to the engine block with a jumper cable. It happened on my L3650 with those tach symptoms..
2018 Chevrolet Suburban 4x4 SUV (A64557)
2018 Chevrolet...
Landhonor Quick Attach Power Rake (A66285)
Landhonor Quick...
2025 Wolverine PT-16-02C Class 2 Three Point Hitch Skid Steer Attachment (A64553)
2025 Wolverine...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
JCB 3TS-8T TELESKID (A65053)
JCB 3TS-8T...
Cub Cadet XT1 Eduro Riding Mower (A66285)
Cub Cadet XT1...
