B21 Tachometer Bouncing
/ B21 Tachometer Bouncing #1
BruceWard
Platinum Member
Central, AR
Above 2500 RPM or so the tachometer starts bouncing around and over reporting. It does not happen at lower rpms and calms down after a while. This started recently after sitting for a few months.
Any ideas?
/ B21 Tachometer Bouncing #2
I rarely run my B21 above 2000 RPM, but sounds like a moisture / electronic issue. The tach is electronic not mechanical from what I recall.
/ B21 Tachometer Bouncing #3
Any ideas?
Check for a bad ground.
Try the battery ground first. Ground the battery directly to the engine block with a jumper cable. It happened on my L3650 with those tach symptoms..
John Deere 2032R Tractor and Loader (A66285)
John Deere 2032R...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 FREIGHTLINER...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
250 gal Livestock Lick Tank (A66408)
250 gal Livestock...
2006 CASE 430 SKID STEER (A65053)
2006 CASE 430 SKID...
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
