B21 work light wiring
/ B21 work light wiring #1
BruceWard
Platinum Member
Central, AR
Does anyone know where the work light wiring should run?
My B21 does not have have work lights. So I bought some to install. The work light slot in the fuse box had a blown 15A fuse. I installed a new 15A fuse and it blew as I pushed it in. There must be a short somewhere.
There are no wires where the work lights would be mounted on the ROPS.
I found a red and black wire that had been cut at the rear near the brake and flasher light on each side. Could these be the work light wires?
How are the work lights switched. Do they come on when the bright switch is switched on or should there be another switch somewhere?
Thanks for any help.
/ B21 work light wiring #2
I installed wal-mart tractor lights on the rops on my B21 several years ago and have not had any problems. There is a lead for the lights that should be on the right side rear axle with a plug. the lead is hot all the time so I installed a toggle switch for the rear and the front lights. When you solve the short problem, you'll probably be able to use that lead.
Thanks Rick, I will find that plug and fix the short.
There are similar leads near both rear axles. They are always powered (not switched).
The parts list shows front work lights connecting to the wiring on the right side and rear work lights connecting to the wiring on the left.
I will post some pics when I wire up the lights.
2021 BROWN & HUBERT 10' SPOOL TRAILER (A63276)
2021 BROWN &...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2022 BOBCAT T76 PLATINUM R-SERIES SKID STEER (A65053)
2022 BOBCAT T76...
2017 HAMM H12i PADFOOT ROLLER (A65053)
2017 HAMM H12i...
2023 BOBCAT L28 ARTICULATED WHEEL LOADER (A65053)
2023 BOBCAT L28...
