Evil the Weasel
Platinum Member
One thing to consider when purchasing a PTO vac for a 2X20 Kubota......... it was discussed when these came out that when the mid PTO is engaged, the rear then turns @ 1080. So...... a PTO leaf vac designed for a 540 rear PTO will now be spinning at TWICE the speed it was designed for. I would have to assume this is why Kubotas bagger will not work on a 2X20 series tractor.
There is an adjustment on the new B's to switch the rear between 960 and 540. You can't run just the mid-pto all by itself on these models. The rear will either be 960 or 540 when the mid is running.
