Thanks for the reply,chriscos.I am not familiar with how the quick attach works,would I need a plate for each bucket or is it just the factory pins that are used.I realize there is one piece for the loader arms but I am not sure what is required for the bucket.Is it just the pin on setup with the pins left on or is there something else needed for the bucket?I am thinking of how the SSQA system works but this system appears different.
So, the currently shipping "pin style" quick attach for the LA504 loader (and the others with the same pin spacing) - basically works like this:
You remove the existing pinned on bucket from the tractor.
In place of the bucket - you put the QA assembly on the front arms of the loader.
The bucket gets a pin installed in the UPPER position only - on both sides.
Then there is a pocket on the top of the QA on both sides that this pin on the bucket sits into. A pin gets installed on either side in the lower position - to hold the bucket in place.
All in all - it's much better than having to wrestle out pins and then pound pins back in - if you had no QA at all on the FEL. But it's not as fast or convenient as a skid steer style QA setup.
Which leads to this: if you look at the new Kubota
B3350 tractor that is coming out - Kubota is now making available a "skid steer style QA" for the LA534 loader on this tractor. I have already confirmed that the pin spacing on the LA534 - is the same as the LA504 on my
B3200 (and hence is the same as all the other loaders that match up to the pin spacing of the LA504). I confirmed this by looking at the part numbers for the pin-on style buckets (54" and 60") - for the LA534 and the LA504 - and they are the exact same part numbers in the Kubota online parts catalog.
So...... it appears that very shortly there will be a skid steer style QA available for the older tractors too. By simply buying one of the new QA setups from Kubota. I call it "skid steer style" - because some of the dealers have piped in on other threads here on TBN - and said that the Kubota QA is not interchangeable with a "true" skid steer QA setup. Until I can actually get my hands on the new Kubota QA (they haven't shipped yet) - I can't tell you where the dimensional differences are.
There are other options available out there for a skid steer type QA setup - are aftermarket solutions like ATI - and I think if you compare the Kubota solution to the ATI solution - you'll see that the Kubota setup is better - whereas the ATI setup is sort of cobbled together. It's too heavy - pushes the bucket out too far (reducing capacity) - etc.
Here's the information for the new Quick Hitch for the LA534:
Quick Hitch : PN#: B2366 (Hitch Quick LA534) - would also show up possibly as 7J056-36103
Pallet Fork Frame for new Quick Hitch: PN#: B2376 (Frame Pallet Fork) - would also show up as 7J056-091260
54" Bucket for Quick Hitch : PN# B2324 (SQQBKT 54) - would also show up as 7J056-51000
There's a 60" bucket available also - I just don't have the part number in front of me.
