b2400 starts, then stalls immediately
   / b2400 starts, then stalls immediately #11
You said that the expected resistance of that solenoid was 1.5 Ohms. Where did you get that information?
Info comes from the Workshop Manual Tactor for B2400 page 9-S13
</font><font color="blue" class="small">( I would disconnect the fuel solonoid then put a fuse back in the spot that keeps blowing to see if it still blows.
If it does then check your ign switch and wiring. )</font>
Already did this. With the solenoid disconnected the fuse does not blow, and the engine turns over but does not start. With a blown fuse and the solenoid connected, when the key is turned to the start position, the engine turns over, starts, and then dies immediately when the key is turned from the start position to the on position (during which the starter is disengaged).
I don't understand how the solenoid is powered if the fuse is blown. Why does the fuel flow at all if there is no power to the solenoid. Remember the fuse is blown. Is there some other mechanism that allows fuel to flow when the key is in the start position?
Thanks Tom
   / b2400 starts, then stalls immediately #14
Not that I'm aware of.
Your blowing the fuse with the fuel solonoid connected means to me a fuel solonoid should be changed.
I concur. I pulled the solenoid. Then I hooked it up to the battery to see if the plunger would operate. It did not. Also the wires entering the solenoid appeared odd. Perhaps melted?? And I could see bare wire if I bent the wires.
I'm going to get a new solenoid. I'll see if that fixes the problem.
If anyone has any other input please feel free to let me know. I'm not overly confident that its a bad solenoid. It appears to be the most likely candidate right now. I'll continue to update this post.
Thanks for everyones' help. Tom
   / b2400 starts, then stalls immediately #16
That solenoid is about $130. If you have the workshop manual, it will give you all the ohm values you need to determine if it's bad. ...sounds like it is bad!
When mine died, the engine would only run when the key was in the start position.
Peter, Did your fuse blow when you attempted to start? I already checked the resistance.
For terminal 3 to terminal 2, the resistance measured .3 ohms vs the book value of approx .4 ohms.
For terminal 1 to terminal 2, the measured 2.5 vs the book value of approx 1.5. I measured it again later and the resistance was 1.7 ohms
The resistance seems to be in range. Which is why I'm not confident that the solenoid is bad.
However the solenoid fails the Fuel cut off solenoid test. When I run power directly from the battery to the solenoid, the plunger is not attracted. According to the manual this means the solenoid is faulty.
My question is Would a faulty solenoid cause the fuse to blow?
Thanks Tom
Problem solved. Replaced the solenoid. Starts perfectly.
One note. I checked the resistance of the new solenoid. It measured 12 ohms. This does not agree with the manual. The manual says approx 1.5 ohms. I'm guessing the manual is in error. Probably should read approx 11.5 ohmns. This makes sense. because Amps = volts/ohms. 12volts/12 omhs = 1 amp. 12 volts/1.5 omhs = 8 amps. Remember I was reading about 2.3 ohmns which would be greater than 5 amps. Actually I took several readings and the actual resistance varied from about 1.8 to 2.5 ohms.
Well anyway replacing the solenoid fixed the problem. Thanks for everyones' help. Tom
2008 International 4400 (A50323)
2008 International...
16ft Trailer T/A Equipment Trailer (A50322)
16ft Trailer T/A...
Diesel Forklift (A51691)
Diesel Forklift...
2008 NEW HOLLAND B95 BACKHOE (A51242)
2008 NEW HOLLAND...
2019 CATERPILLAR 272D2 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
2012 INTERNATIONAL WORKSTAR 7500 (A52472)
2012 INTERNATIONAL...
