B2601hsd for small horse farm?
   / B2601hsd for small horse farm? #11
Kubota B2601 Dimensions
Wheelbase:61.4 inches
155 cm
Length:94.5 inches
240 cm
Width:49 inches
124 cm *
Height (ROPS):85 inches
215 cm
Weight:1632 lbs
740 kg
Ground clearance:12.8 inches
32 cm
   / B2601hsd for small horse farm? #12
Looking at buying one of these as it seems small enough to be maneuverable for cleaning run-ins and has the mid-pto so it can be used as a mower on our roughly 17 acres of pasture.
Can this machine really do all of this?
A 1,600 pound bare weight tractor is fine for cleaning stalls.
It is unsuitable for demanding general farm tasks on 17 acres of fields. A 3,600 to 4,000 pound bare weight tractor, such as the Kubota MX series or deluxe 'Grand L' series (L3560 through L6060) is the usual recommendation for around 20 acres of ground. Too large, however, to work in a barn.
NO.
Most tractors under 3,000 pounds bare weight operate in residential or hobby farm applications on one to ten flat acres.
Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider implements for a new, heavier tractor requires a lot of time. Depreciation on implements is worse than depreciation on a tractor.
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
BUY ENOUGH TRACTOR​
   / B2601hsd for small horse farm? #13
I ended up getting a Kioti 2610 due to it's lifting capacity (1800 lbs). It's also heavy for it's class, and cheaper........maybe take a look at one?
Found this video on YT:
Winchester Decorative Sign (A55758)
Winchester...
2023 Chevrolet Tahoe FL SUV (A55853)
2023 Chevrolet...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A55302)
Mahindra 4550-4L...
2008 Chevrolet Impala LT Sedan (A55853)
2008 Chevrolet...
20' Sea Container (A47477)
20' Sea Container...
