Oil & Fuel B2660 Snowblower Gearbox Oil
   / B2660 Snowblower Gearbox Oil #11
Thankx K1, i will keep a an eye on those plates and the main horozontal drive gear behind the fan. This drive gear was only pressed onto the shaft on my B2650. She spun on the shaft when i put it under serious load. I slid the gear back in place & hit it with the mig welder, no more problem there!
   / B2660 Snowblower Gearbox Oil #12
Good info guys.
I'm tuning up an old 6 foot McKee (3ph) snowblower before the snow arrives. Can anyone give me some idea as to how much tension there should be in the drive chain ??
   / B2660 Snowblower Gearbox Oil #13
There was a good tip in the shop tips thread a while ago. Make sure you can remove the fill plug before you remove the drain plug.
Dave
KubotaOne said:
Kubota recommends SAE90 gear oil. Remove the top and bottom plugs, drain, replace the bottom plug, and fill until the oil starts coming back out the top plug.
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
CAT SMOOTH EDGE SKID STEER BUCKET (A52472)
CAT SMOOTH EDGE...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
PREDATOR  2IN GAS WATER PUMP (A52472)
PREDATOR 2IN GAS...
