B2910 Diff Lock
   / B2910 Diff Lock #11
Cade said:
I'm a Kubota rookie.....I know what the dif lock does and the advantages, however can I engage it while in 4wd? I have yet to use it and probably could have on numerous occasions. After reading your posts I realize that you should be stopped first and then engage the dif lock only long enough to get you out of that sticky situation.
thanks
Yes, you can use it in 4WD but apparently you do need to be stopped. You are not suppoe to try and steer while the dif-lock is engaged. With chains on my back tires and the dif-lock engaged my tractor has amazing traction
   / B2910 Diff Lock #12
you can't steer while using the dif. lock? Thats good to know. I have much to learn.
Thanks again
   / B2910 Diff Lock #13
Thanks again
yep, you and me both......it all comes with time and experience but mostly I have used the great advice from the guys on these forums.
   / B2910 Diff Lock #14
Well I must be tearing stuff up becauser I use the diff lock with a spinning wheel (ok I let off some) and steer at the same time. I fact in soft soil I hold the diff lock down (the bx doesn't have steering brakes to stop a spinning wheel) with a full box blade just to get some forward movement in 4 wheel drive.
   / B2910 Diff Lock #15
I finally used the dif. lock this morning towing out a car stuck in a snow bank. I am pleased! I wish I would have checked out this cite a few months ago. I probably would have used it numerous times by now.
   / B2910 Diff Lock
I use my Diff Lock a lot!!!! That's why I was unhappy about having to push on it so hard to engage. My JD takes less pressure than the Hydrostat pedal to engage. The Diff Lock is just as important for traction, or possibly more important, as 4wd in side leaning positions.
John Deere 637 Disk (A50514)
John Deere 637...
2012 BMW 528i AWD Sedan (A50324)
2012 BMW 528i AWD...
5' X 20' 3/8" THICK STEEL PLATE (2) PIECES (A51244)
5' X 20' 3/8"...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2020 FREIGHTLINER CASCADIA SLEEPER (A51222)
2020 FREIGHTLINER...
