Jul 5, 2001 / B2910 Tractor weight #1 L Leef Bronze Member Joined Nov 5, 2000 Messages 50 Location Iowa Tractor Kubota B2910 FYI, when I recently rented a b2910, I was able to drive it onto the big freight scale for direct weight measurement as follows: b2910 + la402 FEL + landpride 5ft brush cutter(med duty?) = 3260 lbs I thought that was worth posting for others who'v guessed at weights before. Leef
Jul 6, 2001 / B2910 Tractor weight #2 G glennmac Veteran Member Joined Aug 21, 2000 Messages 1,586 Location Western Connecticut Tractor 2003 Kubota L3430 Leef, this is good info. Please tell us what model Landpride brush cutter you have. We can then subtract it. I have a Landpride catalog and they also have a website. What type of tires do you have and are they filled?
Jul 6, 2001 / B2910 Tractor weight Thread Starter #3 OP L Leef Bronze Member Joined Nov 5, 2000 Messages 50 Location Iowa Tractor Kubota B2910 Glenmac, This was a rental tractor I used to try out the r-4 tires (see "Tire question with a new slant" thread. The tires were not filled. My own b2910 now has fluid filled turf tires to help with stability. I should post that follow up on the other thread. Leef
