B2920 Hydraulic cap issues
   / B2920 Hydraulic cap issues #1
rburli
Purcellville,Virginia
Kubota B2920/ Case 311B
Good evening
I have a B2920 with a FEL. Pretty much since the tractor was delivered bran new the hydraulic caps will not stay on the ends. This is turn cause hydraulic oil to leak down on to the tractor and the cutting deck when the FEL is off the tractor. Any suggestions on what I can do to resolve this problem is very much appreciated.
Thank you
Bobby
   / B2920 Hydraulic cap issues #2
My B2620 is now 3 years old with the FEL and the MMM. Those color coded caps seem to swell after awhile and won't stay on. So I've been taking some tin foil squares that I cut to fit over the hydraulic connectors, then push the caps on and they will stay in place. I usually don't run the MMM with the FEL mounted.
On the other hand, I use the FEL with a rear implement and then need the tin foil to hold the two color coded cap pieces together so dirt doesn't build up in the caps. It's kind of a pain, though, to fool with them.
And.....Welcome to TBN....even though I'm not an official greeter.
Cheers,
Mike
Mike
Thank you very much for the advise. I will give it a try and let you know my results. Thank you for the welcome as well.
regards
Bobby
   / B2920 Hydraulic cap issues #4
You can get replacement caps at TSC. Every time I switch my FEL out with the plow or the blower I loose a few drops of the fluid. After a bit it almost looks like I am leaking fluid on my shop floor. I have found it is normal to loose a bit of fluid. Welcome to TBN.
   / B2920 Hydraulic cap issues #5
If they are coming out of the connections for the FEL, there should be some kind of a lock for the loader.
2019 TY-CROP MANUFACTURING LTD DRY BULK TRANSPORT TRAILER (A45333)
2019 TY-CROP...
2016 UTILITY VS2RA 53FT REEFER TRAILER (A43003)
2016 UTILITY VS2RA...
YANMAR SV08-1B MINI EXCAVATOR (A45333)
YANMAR SV08-1B...
2022 Bobcat E60 Excavator (A42203)
2022 Bobcat E60...
2013 FORD E350 BOX TRUCK (A43004)
2013 FORD E350 BOX...
2006 CHEVROLET SILVERADO PICKUP TRUCK (A43004)
2006 CHEVROLET...
