B3030 difficulty steering under load
   / B3030 difficulty steering under load #1
hazmat
Elite Member
West Newbury, MA & Harrison, ME
Kubota L5460HSTC
Back for a visit after 3 years of mostly MIA
Work has been rather insane for me since Jan 2009, plus with the 2 kids growing up fast, I've spent very little time on tbn in the last 3 years. Back for a visit to search for answers since my B3030 is having steering issues with a heavy load...
Nice to see some of the regulars from waaaay back still around.
To catch y'all up on my tractor happenings: Just Past 400 hrs on the Kubota
Built a 1,000 sq foot patio & deck that lasted the summers of 2008 thru 2010 - I'll have to dig up some pix. Tractor & Backhoe were indespensible for that project
Only new implement in the last few years has been a timerwolf PTO log splitter with 4 way wedge - love it. Also bought a new chainsaw (Stihl MS441CQ) a couple years ago.
Bought a new F250 diesel last month - figured you guys would share some excitement about that - (wifey isn't feeling the love). The new diesel is amazing. Got the base XL version, roll up windows and all. Will keep my car for commuting to the office.
   / B3030 difficulty steering under load #2
Re: Back for a visit after 3 years of mostly MIA
Welcome back. :thumbsup:
Cannot help with your steering problems.
   / B3030 difficulty steering under load #3
Glad to see your doing well Hazmat. You need to check in more often.
MarkV
   / B3030 difficulty steering under load #4
What's the issue? I did not see it under owning and operating? I may have missed it?
My 7800 started doing jerky steering when hot running at full speed. Just over 500 hours.
Fluids and Filters fixed that.
Welcome back.
   / B3030 difficulty steering under load #5
"steering issues" Like what issues? not working, surging? I wonder if it's similar to the cracked return hoses very common to the L2800/L3400 that allows air to be sucked into the system?
Welcome back, too... (there is life beyond TBN :laughing::confused:)
issue is difficulty turning with a medium to heavy load on the loader on a hard surface. I have the shop manual & have checked the obvious - hydro fluid is full. Fluid and filter changed at 300 hrs, just past 400 now.
Powerwashed the tractor the other day - will be looking for leaks.
Next up in the troubleshooting is to check pressure - unfortunately I don't have a hydraulic pressure gauge - perhaps it's time to get one set up...
I should really post this in owning & operating.
I'm having difficulty turning with a medium to heavy load on the loader on a hard surface. I have the shop manual & have checked the obvious - hydro fluid is full. Fluid and filter changed at 300 hrs, just past 400 now.
Front tires are filled to max PSI (22psi), rear tires are loaded & have 500# weight box on the rear.
Open to suggestions on further troubleshooting....
   / B3030 difficulty steering under load #8
You're not a novice to tractors...have you ever had this problem before when moving a similar load?
As far as hydraulic pressure (or lack of)...any other symptoms that may indicate that? When you lifted the "medium to heavy" weight...any protests from the loader?
It's been going on a while. Doesn't seem to tie back to any particular event (fluid/filter change etc.) When new, wasn't an issue, so I figure something has worn etc.
   / B3030 difficulty steering under load #10
Yep...worn, or something is bent...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
Case SV280B (A60462)
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A60429)
2014 GENIE...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
Freightliner Tender Truck - Adams Tender (A56438)
Freightliner...
