B3030 hstdc, wont crank over,
   / B3030 hstdc, wont crank over, #1
John White
Newark, Oh
Bob Cat Ct335
Need some suggestions before I start checking. Just bought a B3030, after a long trip home went to unload it off the trailer and it wont crank over. Battery and connections are all right. (full voltage) I didn't have time to really check it over as it was late. It acts as lock out switch in preventing it from cranking over. PTO lever disengaged. It has a parking brake switch somewhere according to manual. Would this prevent it from starting if parking brake is on or switch is bad. I really can't check out much as it in on a trailer with sides and a belly mower. Can"t get to any thing much. Here is what I do know, I have another B3030 and I disconnected both under seat switches and tractor will still start so I don't think those switches will affect it. It will start with parking brake on . (maybe it's not suppose to with brake on, but it does) Next I am thinking HST switch. Don't think I can get to it on trailer. Bottom line, can I remove side panel cover and just jump the solenoid to get it started so I can get it off trailer? I can't pull it off because mower deck is down and so is bucket and no steering without engine running.
   / B3030 hstdc, wont crank over, #2
yes you can jump the solenoid or starter. get it out where you can get to things and then do your troubleshooting. that is what I would do also
Jumped the solenoid so I could get it off trailer and into shop. Took mower deck off so I could check HST switch. I checked all the lockouts and seat. Still wouldn't start. This is where I had a brain failure. I remember it was late when I got in and put the key in to start it. I remember that the key just turned freely like it wasn't turning any thing. Turned it back and took key out and realized I had put the door key in it. I put the ign. key in and everything worked but wouldn't crank. After spending 4 hours checking every thing out I put the door key back in it turned it to the crank position and pulled it out, then put the ign. key in and it cranked fine. Problem solved. I guess I had a dumb attack.
   / B3030 hstdc, wont crank over, #4
I betcha you want your time back for that one... lol
   / B3030 hstdc, wont crank over, #5
it only cost you some time apparently you were supposed to learn a lot about your new tractor
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A52709)
2019 KOMATSU...
16ft T/A Flatbed Trailer (A56858)
16ft T/A Flatbed...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58216)
30 INCH TOOTHLESS...
2015 JOHN DEERE 35G EXCAVATOR (A52709)
2015 JOHN DEERE...
2.5 POLY PIPE (A58216)
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
