B3200 Steering problem- need help
   / B3200 Steering problem- need help #1
britman1021
South Jersey
I have a B3200, almost 50 hours and about to go for service.
In the last hour of use- while using my box blade I have noticed the steering getting very tight. Moving through 3/4 lock left or right or moving through center it takes a lot of effort.
Raised the front off the ground with the loader, so there is no ground contact- problem is the same.
Does anyone have any ideas.
   / B3200 Steering problem- need help #2
Sounds like something in the steering box is amiss. With the front end off the ground it should steer effortlessly, even without the tractor running. I'd let the dealer look at it as it should be a warranty issue. If it is they should be able to swap out the steering box pretty quick.
EDIT: Also make sure nothing unusual is going on with the steering linkages and that nothing is jammed under the steering arm on the axle. Aside from that it is probably related to the steering box.
Thanks for your input, Verticaltrx,
I hoped that the no load test would suggest something.
Its always better to have an idea when you deliver the vehicle to a service manager you don't know. This is not my first Kub, but its a first from this dealer.
7ft. Bush Hog Squealer SQ7 3pt. Rotary Mower (A46502)
7ft. Bush Hog...
Used Empty 55 Gallon Drums (A46502)
Used Empty 55...
3121 (A46502)
3121 (A46502)
Fuel Barrel w/Stand (A46502)
Fuel Barrel...
Mitsubishi FG35 Forklift  8,000lb Lift Capacity, LP Gas (A48561)
Mitsubishi FG35...
2015 Takeuchi TW65 Series 2 Wheel Loader (A46502)
2015 Takeuchi TW65...
