b3200 use bh75? and other questions (bx vs)
   / b3200 use bh75? and other questions (bx vs) #1
grizzjeeper
Bronze Member
Fairfield Maine
Kubota l3400 HST
Currently I have a bx2230 and a l3400 hst. Both have loaders, BX has 60 mower deck and the l3400 has a bh75 backhoe. The L doesnt get used very much any more so i am thinking about consolidating but need something bigger than a BX line. The big question is i dont want to "rebuy" a backhoe and since it seems so similar to the new bh76/77 series is there a way to make it work on the b3200? I assume I would need a different subframe. I see before the bh77 the b3200 would take a bh76 and i am pretty sre the bh76 and 75 were the same as far as mounting points. Is the 77 the same as well?
Anyone comment on mowing with the b3200 coming from a bx?
   / b3200 use bh75? and other questions (bx vs) #2
Had a BX23TLB with a 60"mmm, mowed great, also had a B3200TLB but mowed with a Woods 72" rear finishing mower, liked that better then the mmm. You'll find that some people like mmm while some like RFM. I like the latter as it's easy on easy off, just my take.
DevilDog
   / b3200 use bh75? and other questions (bx vs) #3
The Kubota BH75, and BH76 use the same mounting system as far as I know, and are dimensionally the same where they mount. As you said, you will need a new sub frame, but it should work fine on the larger B series tractors, and many were fitted with them when the BH75 was a new thing. If it is a Woods BH75 it will work too. You will find the B lighter, and more nimble than your L for sure. Actually for my uses, if I had a BX for mowing, and snowblowing, I would look hard at the B3300SU
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A44572)
2018 Toro...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A43003)
2017 KENWORTH T680...
Countyline 15 Gallon ATV Sprayer (A44391)
Countyline 15...
(1) HD 12ft 6in Panel (A44391)
(1) HD 12ft 6in...
New/Unused 20ft Bi-Parting Iron Gate (A44391)
New/Unused 20ft...
2015 Ford Taurus Sedan (A44572)
2015 Ford Taurus...
