OP
rusticgrain
- Joined
- Nov 20, 2020
- Messages
- 11
- Tractor
- IH B-414, mf10
I'm able to start the tractor in gear, let it run for a few hours yesterday and took it for a drive up the road in second gear, high, locked up the brakes several times and it still won't come free. Also tried towing it around a bit with my father's 135, same, nothing.
All of the fingers do move, and from what I can see, the springs aren't broken. If I take a block of wood and put it between the throwout bearing? And the pressure plate, when I press the pedal down the throwout bearing will only go as far as the block then the pedal goes to the floor board. Seems like the pedal just won't move forward enough to put any pressure on the pressure plate. I'm not sure how far out the pressure plate should sit on the shaft towards the back but I'm wondering if the pedal might need to be adjusted somehow?
