B7100 Grease Fittings
   / B7100 Grease Fittings #11
Well I called a couple of dealers about my Kubota 1630 FEL with the numbers that Chuckanut gave me, they all said the grease fitting was "L" shaped. So something must be wrong because as little as I know about tractors the part I'm looking at is not "L" shaped.
I got through to a mechanic at one place and he said to pull one of the other fittings out using vise grips then bring it in for a match up. I hope I'm not going to be looking for two fittings because I've ruined a perfectly good fitting.
Also it does look like this grease fitting is not threaded but a tap in.
MLD
Answer to highlighted part only
I had the same problem with my old B7100D with the pressed in fittings. I just used and ez-out if they broke off and pulled the pins or whatever the fittings were greasing and taped them out with a standard thread and put in good old American standard threaded fittings. Works like a champ. :)
The Gotcha Man
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
Wolverine Quick Attach Hydro Slide Pallet Forks (A50514)
Wolverine Quick...
2015 CATERPILLAR 745C 6X6 OFF ROAD DUMP TRUCK (A51242)
2015 CATERPILLAR...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2021 JOHN DEERE 410E-II 6X6 OFF ROAD DUMP TRUCK (A51242)
2021 JOHN DEERE...
2017 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2017 CATERPILLAR...
