b7100 tire problem
   / b7100 tire problem #1
1baddtoy
I need front tires for my b7100 4x4 and dont know what size I need. It has 29/12.50r15 turfs on the rear and nothing on the front. I have the rims just no rubber. I was told that I need a 6-12 or a 23x8.50-12. Any thoughts??? I did find a set of 6-12 that are bar tires will that work? Thanks.
   / b7100 tire problem #2
The 23x8.50 sounds right for use with the rear turfs. I can't remember if they have the 12 inch rim tho or not.
   / b7100 tire problem #3
For R1's (bar) 6-12 tires on the front with 8-16's on the back.
For turfs, you need 29x12-15 on the back, and 20.5x8-10 on the front.
can I run the 6-12 on the front and the turfs on the rear? The local kubota dealer couldnt tell me crap about this. they said it shows 6-12 fronts that are turfs for $100 ea. I found 6-12 fronts that are bar tires online for $130 a pair.
   / b7100 tire problem #5
No, they are too large in outside dia.
8-16's are about 31 in. in dia, where the turfs are 29 in.
ok so I found a set of at101 chevrons that have a mounted diameter of 20.9in. will these work? I am having a real hard time finding tires. Kubota keeps saying that I need a 6-12 but I have turfs on the rear and I dont want to buy wheels and tires for that too...
   / b7100 tire problem #7
You've only 3 posts.
Use the search feature.
There's a place that sells and ships "blems" fo a real reasonable price.
It doesn't matter how many posts I have. I have been searching online (this site and others) and calling multiple dealers for almost two weeks and I can't get the answer I need.
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2021 Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A60429)
2014 CATERPILLAR...
