B7500 Loader "lift" and "dump" cylinders leaking
   / B7500 Loader "lift" and "dump" cylinders leaking #1
don716
North Georgia
Kubota/ B7500/with 2000 lb winch
My cylinders are leaking on my LA302 loader. Where can I get the rebuild kits for them? I cannot find anything online. Thanks.
   / B7500 Loader "lift" and "dump" cylinders leaking #2
Kubota dealer is a good place to start and get a price, then go from there.
   / B7500 Loader "lift" and "dump" cylinders leaking #3
Are the cyl leaking internally or externally?
It's not squirting out but it does drip out enough to run down my front tires. I thought just one was leaking but figured out all 4 was leaking so a rebuild is needed I think.
   / B7500 Loader "lift" and "dump" cylinders leaking #6
A shop that sells hoses and fittings may rebuild the cylinders for you. The chances are the cylinder will take generic parts.
   / B7500 Loader "lift" and "dump" cylinders leaking #7
Rod seal. ... May slow appreciably when the weather warms and give you a reprieve until winter next.
   / B7500 Loader "lift" and "dump" cylinders leaking #8
I used to rebuild my own - depending on the cylinder design it can range from easy to do to difficult. But then I got smart and started taking cylinders to a little hydraulic shop in a neighboring farm town. They seem to use a lot of generic parts - but the cylinders come back looking and working great for a reasonable price. They also make hoses for about half what the dealer charges.
It's not unusual for these little shops to not even advertise. Look to your local ag community - where there's a cluster of tractor dealerships there's likely to be a hydraulic shop somewhere nearby.
rScotty
Kubota ZG327 (A50120)
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
MAH QUICK ATTACH MAST W/ 48" FORKS (A51246)
MAH QUICK ATTACH...
New Wolverine Push Blade (A53002)
New Wolverine Push...
40' shipping container (A52377)
40' shipping...
2017 SANY SY365C LC EXCAVATOR (A51246)
2017 SANY SY365C...
