Dargo
Super Member
- Joined
- Mar 6, 2004
- Messages
- 5,981
- Location
- S. IN
- Tractor
- Jinma, Foton, TYM, Belarus, Yanmar, Branson, Montana, Mahindra and maybe some green and orange too.
Hmm, me thinks you might want to not do what I did. Every time my 12" auger on my Lienbach L7400 bit hard in the ground I broke the stinking 5/16" shear pin. So, I put on a slip clutch. I apparently didn't have the slip clutch adjusted loose enough. I can now tell you that my 5030 will twist the 12" auger you have in half at just above an idle. /forums/images/graemlins/mad.gif
I just got back from buying a better auger. I'd take pictures of the destroyed one, but my temper got the best of me and there isn't much left. /forums/images/graemlins/blush.gif I can tell by the picture that you haven't done the shear bolt drill very often. All of your shields are still on. /forums/images/graemlins/grin.gif
The L7400 seems to have a decent gear box and all, but that 12" auger isn't just too strong. Maybe with a smaller tractor and staying with the very easy to break shear pins you will be okay. I need to bore around 5000 holes. I was having to replace the shear pin about every 6 to 8 holes. I just didn't feel like changing 800 or so shear pins!! Hopefully after another turn on the clutch nuts and a much heavier 12" auger I'll be okay.
Just a suggestion. Next time you are by a Rural King or a hardware store, pick up a dozen or so 5/16" X 2 1/2" grade 2 bolts and nuts. I quit screwing with the lock washers. They never stayed in long enough to worry with them. Anybody know how this PHD would work if a guy used grade 5 shear bolts? With the grade 2, I can tell you spend more time changing the shear bolts than digging if you have heavy clay soil! If you have rocky soil, don't even try it with the standard 12" auger.
