b7610 frozen loader joystick?
   / b7610 frozen loader joystick? #1
WiJC
Wisconsin
kubota B7610
the last few times ive used the tractor, it has been below freezing. (7 degrees out yesterday)
the loader will go up and the bucket will curl, but i cannot dump or drop the loader until the tractor has run for about a half hour or more...then all works fine.
is it possible i have some water frozen somewhere that would cause this?
thanks
John
   / b7610 frozen loader joystick? #2
Had the exact problem with my B2910 and 402 loader. I took off the Plastice cover on the loader control, found that snow had blown up under it. There is a small tie rod link that they use as a universal joint, that had iced up, a little shot of WD-40 from the house was enough to warm it and melt the ice hopefully the WD40 will displace the water and it will be A OK!
   / b7610 frozen loader joystick? #3
WiJC -
I just replied to another post - click here for the other thread / pictures that I just posted.
The "float" position hasn't "locked" in on my B7610 for over a year - although the float works if I hold it there. I had the same problem as you early last winter - but it was my "dump / curl" - my up/down worked fine.
I think the spring covers at the bottom end of the FEL valve are the problem in either case - some water gets into the hydraulic system (condensation - or leaking at the fill cap) and "pools" there - and freezes / causes corrosion etc. - causing one or both of the FEL valves to stick until warmed up.
Hope that helps,
Dan
UNUSED LANDHONOR DDSL FUEL TRANSFER PUMP (A50460)
UNUSED LANDHONOR...
New/Unused 4ft Bush Hog BH114 Rotary Cutter (A48837)
New/Unused 4ft...
2013 Ford Taurus SEL Sedan (A48082)
2013 Ford Taurus...
2014 Jeep Grand Cherokee Multipurpose Vehicle (MPV), VIN # 1C4RJFAG3EC371355 (A48836)
2014 Jeep Grand...
New/Unused 7ft 10 Drawer Work Bench (A48837)
New/Unused 7ft 10...
BrandFX Truck Bed Cover (A50860)
BrandFX Truck Bed...
