B7800 crank but no start - basics first fix
   / B7800 crank but no start - basics first fix #1
Mudder
Georgia
Kubota B7800
The dreaded crank but no start, with good starter rpm spin but no usual audible “click” from electrical components. Although the battery has been on a Ctek smart charger showing fully charged, I still reverted to a Noco jump pack first to just to rule out a good 12v indication but insufficient CCA (based on atv battery experiences). Sure enough it fired right up. Point being that battery voltage alone can mislead, and fail a load test, so try the simple things first and cross fingers. Regardless still appreciated the many informative threads on similar issues. This was a Kubota battery only 1 year old, on a smart charger during winter.
   / B7800 crank but no start - basics first fix #2
I had a battery once show 12.6v. But when you went to crank it it would drop to next to nothing. It showed next to no warning. It was a napa gold about 5yrs old.
   / B7800 crank but no start - basics first fix #3
Something doesn't quite add up.
You say the starter was spinning at good RPM but the engine only started when you jumped the battery?
Did you notice that engine RPM increased when starting after the battery was jumped? If it was the same to your ears, then again, something doesn't add up. Coincidence maybe?
Perhaps the problem is still awaiting to reappear.
Thanks for your reply. Observation with the jump pack was return of the single audible click at the first key-on position.
Suspecting the click was a fuel solenoid or similar relay, which required just a bit more electrical voltage and/or amps to activate.
Yes the starter may have spun a bit faster, but (subjectively) it seemed fast enough given 19 years of ownership. A 2004 model purchased new.
So guessing just either a weak battery, a solenoid/relay at early stages of failure as you mention, or a combination of both. Seems if there was enough power to spin the starter, the solenoid would not be so sensitive as to not activate.
Reason for the OP was viewing numerous “crank but no start” posts that focused on replacement parts, with no mention of a battery CCA load test/status first.
Update with fix. After several months the intermittent problem got worst. Fixed with stop fuel solenoid relay and solenoid replacement.
2019 TY-CROP MANUFACTURING LTD DRY BULK TRANSPORT TRAILER (A45333)
2019 TY-CROP...
2011 GMC Sierra Reading Service Truck (A44571)
2011 GMC Sierra...
7' Fork Extension (A44502)
7' Fork Extension...
2015 Ford F-450 Knapheide Service Truck (A44571)
2015 Ford F-450...
Pallet of Irrigation Hoses (A44502)
Pallet of...
2021 FREIGHTLINER CASCADIA DAY CAB (A43004)
2021 FREIGHTLINER...
