Carl_NH
Elite Member
- Joined
 - Apr 5, 2002
- Messages
 - 3,906
- Location
 - Coastal NH
- Tractor
 - 01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
Helping a cousin in CT spend some $ this weekend looking for the best setup for their needs.
- Brush clearing, moving rocks and some BH work weekly (for next 12 Mos)
- Mowing weekly
- Small stump removal - 6-9" Typ
- Landscaping trenching and finish grading in 2003
- Plantings, Lawn Maintenance, in 2004
- Terrain is gently sloping land, soft in spots (wet) with a few rocks and stumps
They have 10 Acres, doing a major remodel on the house which the heavy work will be done with an excavator and dozer, howver much is left to do.
I recommended the B7800HSD with BH, 60" MMM.
We went looking today and found a B7800HSD & R4's with a Bradco 3375 with a NEW 4 Point connection setup not using the 3PTH arms but is connected directly to a subframe ala the TLB series but not quite as robust. This box frame attaches to to rear axle, then under the tractor to the mid point frame. The removal and refitting appears to be similar to the TLB series insomuch that the BH carriage sits in a frame and is powered by the tractor hydraulic system.
While all of this is appealing, the dealer indicated while MMM is possible the tradeoffs between the MMM and a RFM and said "no one tool can do it all" so recommended the RFM as the "best solution" since the BH removal and replacement was so easy..
This is the first I have seen of the "4Point Connection" from Bradco and wanted to get feedback on this with a MMM. Also, what about the Woods 7500 and subframe and MMM setup.
While all this sounds fine, in real world pratice it is not the norm as the grass needs cutting and the BH work must be done in the same day with minimal change out of components.
Ideally I would like to have the MMM & BH on the tractor, however understand the issues this presents when working either attachment.
What I want to know have others experienced the Bradco 4 Point system with a MMM, and also those with the Woods 7500 Subframe setup with the B7800 and MMM.
Or do we upsize to the 3130 /forums/images/graemlins/smile.gif?? If so what is the potential for the MMM/BH combo on that?
Thanks
Carl
- Mowing weekly
Thanks
Carl
