B7800 - how big a rotary cutter will it handle?
   / B7800 - how big a rotary cutter will it handle? #21
If the HP rating of the tractor's PTO is greater than 18, I can tell you that the older Woods RM600 will work on your tractor. That's the model I have on my B2400. This mower weighs a smidge over 700 lbs and has a cutting path of 72 inches.
I can cut knee high pasture grass without any trouble.
   / B7800 - how big a rotary cutter will it handle? #22
   / B7800 - how big a rotary cutter will it handle? #23
<font color="blue"> </font>
Where did you notice that in the manual? I have a b7800 & never noticed that limitation. My dealer suggested a 5' BEFCO brush hog for my tractor. I have spoken with several other dealers - land pride, woods, king kutter - and all suggested 5' mowers.
   / B7800 - how big a rotary cutter will it handle? #24
   / B7800 - how big a rotary cutter will it handle? #25
Another vote for the 5' cutter. I also have a 60" brush hog from a company named Lowery Manufacturing in AL. Purchased it with the tractor and have never had any problems using it, even in tall, heavy grass. On several occasions, I've also used a 72" Bush Hog Squealer behind my B7800. With the loader on, I had no probs. mowing a pretty flat field, but the front end was a touch light. I would say that makes a 6' cutter marginal, not a 5'. 60" hits the sweet spot on a B7800.
   / B7800 - how big a rotary cutter will it handle? #26
   / B7800 - how big a rotary cutter will it handle? #27
I have had a 60" Landpride RFM for four years and have not experienced "any" problems doing medium field work with the B7800.
   / B7800 - how big a rotary cutter will it handle? #28
   / B7800 - how big a rotary cutter will it handle? #29
Looks like we're mostly in agreement. I already had a 48" brush hog when I got my B2710 and I promptly traded it for a 60" one. And the B7800 is about the same size as the B2710. Personally, I like one that extends out past the back wheels at least a little bit so I could get close to fences, buildings, etc.
   / B7800 - how big a rotary cutter will it handle? #30
2011 COMPTANK ACID TRANSPORT TRAILER (A55745)
2011 COMPTANK ACID...
2006 FORD F-350 (A53422)
2006 FORD F-350...
MINI ROCK CRUSHER SDLTC (A55745)
MINI ROCK CRUSHER...
2022 Polaris Ranger Utility Cart (A53421)
2022 Polaris...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2018 FREIGHTLINER...
