B7800 shuts off when i get off tractor
   / B7800 shuts off when i get off tractor #11
Not sure about YOUR model tractor...I'll look at mine tomorrow and see> I don't recall the boot on mine....
Its the 7800. There is a rod with a rubber boot and another rod behind that one and the safety switch sits to the left of those rods, but they seem like they are work together.
Thanks for helping
   / B7800 shuts off when i get off tractor #13
Sounds like you have the correct mechanism, As I said earlier in a post, I by passed my switch, (i know the pedal always returns to neutral)
I would check with your dealer on the actual adjustment, although it looks like the rear nut on the rod just prior to the switch. you need to "lengthen" the rod to make better contact with the switch..
Good luck
2006 International 9400i (A51039)
2006 International...
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
2007 MACK CHN613 (A50854)
2007 MACK CHN613...
2015 FREIGHTLINER CASCADIA DAY CAB (A51219)
2015 FREIGHTLINER...
2025 LandHonor LHR-CIA200 200lb Cast Iron Anvil (A49461)
2025 LandHonor...
