B7800 stopped and would not start!
   / B7800 stopped and would not start! #21
I ended up taking apart the linkage under the forward speed control pedal. There is a piston shock absorber looking unit under there (can't remember the real name of it) that brings the speed control pedal back to neutral. I found some junk ( dirt and cloth looking material) on the shaft of the piston on that unit that was stopping it from going all the way. I cleaned it up, lubricated it and put it back together and never had trouble since. Except when I inadvertently move a PTO lever.
   / B7800 stopped and would not start! #22
I have the same problem. i have checked everything including the PTO levers and still nothing. i dont know where to turn. HELP!!!
I had the same problem and found that the hydro pedal centering switch had gotten loose and wasn't making contact when the pedal was in neutral. I found this thread, which led me to a diagnosis and repair. I took pictures of the switch setup, they are at post # 12 in the thread. Hope this helps.
http://www.tractorbynet.com/forums/kubota-owning-operating/153385-kubota-7800-wont-start.html
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2016 CATERPILLAR 330 FL EXCAVATOR (A60429)
2016 CATERPILLAR...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
DEUTZ MARATHON...
10222 (A56858)
10222 (A56858)
2000 Ford F350 Flatbed Truck (A59814)
2000 Ford F350...
