back blade for grading/swails
   / back blade for grading/swails #1
MikeNC
Raleigh, NC
3710HST
Hi all,
I am trying to get a new lot and pasture graded and seeded soon. The final grade around the new house and drive is pretty poor, and I finally sent the guy with the bulldozer home. I am now at the point of "If you want it done right, you gotta do it yourself"
So if the mud, red clay, :( dries up by this weekend, I'll be moving some dirt. I need to get a few percent grade away from the foundation and driveway, and create several swails. A while back I tried using a box blade to cut swails, and tilted it by the adjustment on the 3 pt. The results were slow, and not what I had hoped for.
Before I go out and buy a back blade, I'm wondering if a tilted and angled back blade will give me better and faster results. If I make multple passes in the same direction, will I be able to create a side-to-side slope easier than with a tilted box blade? I hear alot about using them to move snow, but what about dirt/clay? Any thoughts on whether a standard duty (TSC/ Agri-supply type) blade will hold up to this use?
It seems like I can get the job done with a FEL, box, and rear blade, but I'd really like to hear from anyone who has successfully used these implements to do this. If a rear blade is no better for this task, I'll save the money and finish up with the FEL and box.
THANKS!
   / back blade for grading/swails #2
Mike, I just got a rear blade so I don't have a lot of experience yet but here's my take...
My blade is the standard duty King Kutter. Not terribly heavy. I have found it will dig and move previously disturbed soil like around our new house. I tried a section that had old weeds still growing and it just pushed the weeds over, didn't touch the dirt at all. I suspect that by ripping things up with the box blade scarifiers it would work, but then you've already got the box blade on so why not use it.
Again, not a lot of experience yet. BTW, I did get the rear blade primarily for snow removal /w3tcompact/icons/smile.gif
   / back blade for grading/swails #3
I think weight is the key. I've got a 9' Bush hog back blade that has the weight to do the job, but all the adjustments are manual. I use it on my Ford 5600. What I've learned in grading several hundred yards for a fill area is you really need hydraulic tilt to speed things up and enable you to fine tune the blade position to get the slopes you want.
Replacing the adjustible box beam tilt adjustment with a hydraulic cylinder is on my list of winter projects. With that grading slopes will much simpler. FWIW, the dozer operator you had should have been able to do the job if they knew their stuff.
   / back blade for grading/swails #4
Ummmmm....
I'm /w3tcompact/icons/blush.gif to ask this question...but don't have a dictionary...might not get it right anyway...
What's a swail?
Doesn't seem to be part of my Western Pennsylvania vocabulary.../w3tcompact/icons/smile.gif
By the way I REALLY don't know...
Bill in Pgh, PA
   / back blade for grading/swails #5
macher'
actually it should be ....swale
swale
n.
1. A low tract of land, especially when moist or marshy.
2. A long, narrow, usually shallow trough between ridges on a beach, running parallel to the coastline.
3. A shallow troughlike depression that carries water mainly during rainstorms or snow melts.
My father and in-laws are all from east OH and west PA, and they all say swale/swail. Of course they also say "gumbands" (rubberbands), "youn's" (all of you), and "crick" (a creek)
   / back blade for grading/swails #7
It's a wide shallow ditch type thing 6-12 inches deep and 10-12 ft wide Give or take a little variation in the numbers.
What I've found when cutting swales with the box is to cut down the middle of where you want it a few times and then begin sloping the sides with one tire in the previous cuts. The box will fill in the _| section of the cut, leaving a nicely graded area. Less playing with the hitch. Just an idea.
   / back blade for grading/swails #8
I've cut swales with a back blade on a JD 3020 and had moderate success. What worked better for us was a pond scoop. The "bowl" can be shaped pretty quickly with one and the final grade is done with your box blade. We controlled the digging depth with a chain between the scoop and the upper 3 pt link.
   / back blade for grading/swails #9
<font color=blue>My father and in-laws are all from east OH and west PA, and they all say swale/swail. Of course they also say "gumbands" (rubberbands), "youn's" (all of you), and "crick" (a creek)</font color=blue>
Hey! I worsh my face and scrub my teeth too! Drink pop, not soda, and when I want to go where the action is I go downtown...but we pronounce it different that it is spelled...and I can't spell it like we say it . /w3tcompact/icons/smile.gif
Oh...I guess I vote for the box scraper over the back blade for swailing...
Bill in Pgh, PA
   / back blade for grading/swails #10
A less known definition is a terrace used in permaculture. The terrace is imperceptibly sloped toward the down hill side. The idea is that the swale can intercept water coming off a hill and by spreading it out on the almost flat surface of the swale tremendously decrease the water's velocity and give the water time to sink into the soil rather than runoff.
In arid area this a technique of capturing water in the soil. In temperate areas, it can solve erosion problems on hillsides.
2019 Ford Explorer AWD SUV (A48082)
2019 Ford Explorer...
UNUSED Mobile Expandable Metal Barricade Set (A50860)
UNUSED Mobile...
2015 Ford F-750 Crew Cab Liftmoore 2550 5,000LB Mechanics Crane Truck (A48081)
2015 Ford F-750...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
1999 24DTA pintle hitch trailer (A51039)
1999 24DTA pintle...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
