Grading back blade question/advice
   / back blade question/advice #1
kevkubota
upstate NY
BX2200
i bought a bush hog series 20 4' blade with my bx2200, I used it to remove snow, along with my fel about 6 times this winter. After reading all the comments on here i could find about back blades and snow removal, I have decided that it is not wide enough and not sturdy enough for the long haul. So, i have decided to go with a bush hog series 35 5' blade...it is much sturdier, 2 1/2" taller and obviuosly 1 foot wider.....any thoughts or comments or advice would be appreciated...the dealer will just swap it out for me if i choose to do so. By the way...my driveway is blacktop and around 150' long by 12' wide with a large turnaround area near the garage. /forums/images/graemlins/crazy.gif
   / back blade question/advice #2
I won't comment on your specific situation, but let me make a few general comments about my back blade. Sounds like we did the same thing and bought a cheaper blade sized for the tractor we have. I bought a 5' Farm King. It is a light duty blade that rotates 360 degrees with 6 stop angles (3 per side). I've posted on here before indicating that if I had to do it over again I'd still get a 5' blade, but I'd get a "heavy duty" blade with offset and tilt capability. Offset would allow me to angle the blade fully and still push snow well off the driveway. This is opposed to getting a 6' blade which is really too big for a B2410 when you plan on doing dirt/gravel work.
Just my $0.02
Kevin
Thanks for your 2 cents kevin....we definately are thinking the same, so did you upgrade or are you going too?
   / back blade question/advice #4
Haven't upgraded yet. I'm going to pursue the "cheap" method first. There has been a lot of talk on here about using cut rubber horse mats and other items to "extend" the length of a blade and allow the blade to push snow further off the driveway. I've done all my course landscaping now (when I could have used a heavier duty blade) and pretty much just use the blade for snow. I'd rather spend $50 bucks on an experiment trying to lengthen the blade than buy a new one at this point. Never know what will happen down the road though. I do need something other than this blade to improve and maintain the gravel driveway....just not sure if that should be a back blade or a box blade.
Kevin
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
405 (A52706)
405 (A52706)
case 370 glass door never installed (A56438)
case 370 glass...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 SAVANA 3500 16FT BOX TRUCK (A59905)
2020 SAVANA 3500...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
