Back Hoe -vs- Excavator... Which do you prefer?
   / Back Hoe -vs- Excavator... Which do you prefer? #41
Not really, I've cleaned out a lot of ditch by driving along side of the ditch with the backhoe and digging at 90 degrees to the machine and dumping the material as far as 180 degrees away. It also leaves the btm of the ditch round instead of flat. Just have to make sure machine is far enough away the outriggers won't slip into the ditch. My machine does not have the extend-a-hoe, the machine I use at work from time to time does and it's even easier.
Probably not as fast as an excavator but it can be done.
I also dug out 50' of barn foundation 10' deep with my backhoe doing the same thing. This way I could open the trench wide enough at the top so it wouldn't cave in and get the dirt well away from the hole.
You should not dig over the side of your tracks of an excavator...very hard on the tracks and undercarriage which is extremely expensive$$$. Digging in an excavator should be in line with the tracks and over the idler end not the drive sprocket.
   / Back Hoe -vs- Excavator... Which do you prefer? #42
I wasn't using an excavator, it was a rubber tired TLB or what is called a backhoe around here.
   / Back Hoe -vs- Excavator... Which do you prefer? #43
What about a rubber tracked machine?
   / Back Hoe -vs- Excavator... Which do you prefer? #44
I do agree with this for the most part, especially in hard soils, but for ditch clean up I doubt highly there'd be damage. Digging over the tracks can be a bad thing but it depends on soil/spoils being moved/dug. Excavators are counter weighed for a reason, comes down to proper judgement from the operator. An operator could just as easily swing to much weight to one side and have to much force on a track, especially if the machine were equipped with a balde and they used the blade for leverage.
   / Back Hoe -vs- Excavator... Which do you prefer? #45
Its not the amount of weight, excavators are used to crane stuff all the time all around the machine. I think the big issue is the side pull when digging. The "wheels" and others things will slide side ways on the tracks, metal on metal and wear down. When digging with the tracks if the machine does get pulled the tracks will roll as it should. I do agree through that a good operator who is just doing clean up shouldn't slide a machine.
Rubber tracks still have the same issue, probably not as bad though. Around here many highway departments have wheeled machines, then you can dig where every you want for the most part, just not as heavy duty as a tracked machine. Yet for cleaning ditches and putting in small pipe they work great.
   / Back Hoe -vs- Excavator... Which do you prefer? #46
I used my backhoe to clean ditches and it worked OK. A fully articulating bucket would have been real nice. But I have now switched to using the loader on the not so steep sections. It's so much faster and I can now choose where I want the silt to go. Before I did like most, moved it from the ditch on one side and 180 degrees to the other side. Now I'm filling in sections that once full I'll get some grass growing. I would love something a little bit larger than a miniex but I wouldn't sell my BH to buy one.
   / Back Hoe -vs- Excavator... Which do you prefer? #47
To me you really need to consider all your options and what you plan to do with it before deciding which one will be the best fit. We recently started a project to replace over 200 acres of 40 year old fence. Needless to say, we have some clearing to do and I have been looking at used excavators for a few months now. Not really at mini excavators but rather a small full size machine, something in the 30,000 lbs range. Since my knowledge on excavators is just enough to get me into trouble, I asked a very good friend of mine who has many years of experience working with construction equipment to help me look for one.
From the start he was pushing me toward a 4x4 backhoe (rubber tire as we call them) over an excavator simple for its versatility. I wasn't sold on the idea, but as he pointed out, it won't be as fast as an excavator, but in the long run it will be a better all-around fit for farm use. After looking at several excavators that we both agreed weren't worth the asking price, I ran across a pretty good deal on a Case 580 backhoe (4x4). Still not convinced it was the best idea, I decided to give it a try since I already have a NH SL190 Skid Steer loader (which is a large machine)and I was thinking the two might be a good fit.
So far we have cleared about 3,000 of pretty bad fence and I have to say that I'm impressed with what the 4X4 backhoe will do by itself, but when paired with the SS it really makes things go faster. Now, there's no way it's going to out dig or perform a 30,000 lbs excavator for what we are doing, but when you consider the cost advantage, it does the job nicely. It was also really nice that I could just drive it down the road to complete a few small jobs that I wanted to do and drive it back within an hour.
I still would like to have a small excavator and if the right one at the right price where to come my way I would jump on it, but I don't think the backhoe is going anywhere. I'm satisfied.
Your friend was a good resource to use it sounds like.
We picked up a bit smaller 24" hoe and 7.5' FEL) 1983 JD 310B 2WD backhoe in 2010. It starts and runs fine without using engine oil but both ends have a lot of wear so we just keep it greased up.
The more I use it the more I realize it can do. It does require some brain power/forethought often.
The lot our church sets on is in a location that is becoming swap due to beavers, drainage stoppage and rising water table (has to add a foot to the 4" well casing because water started flowing over the top with no power to the well).
The guy that owns the land on two sides ditched about 10 years on both sides that dried up the church propery but they were about filled in and since he lets the church keep the field behind the church mowed to be used as a playground I offered to clean them out.
I learned working from 90 degrees was about as fast as digging in a straight line but if one reaches a lot the banks can have a saw tooth look. :)
Like Ken I ran I a what to do with the dirt issue to get finished. The last dig was along the road that is about 12' wide and I had to dig from the road with no where to pile the dirt other than in the road then there was not way to load it on the truck so I just loaded it directly onto the very high F700 16' flat woooden bed dump truck with 30" sides.
This saved a mess at best and saved a lot of time/energy as well. Another plus was my 14 year old son learned to move it forward and backwards on the fly because it was too much climbing for me to do every 10'. :)
After we got 6-10 ton loaded (water logged clay) we would dump it and go again. I found by lifting the rear tires around 15" with the fronts on the ground I could get the hoe bucket like 36" higher when fully extended but that it was not necessary to clear the 30" sides.
The backhoe cost $7200 and the Ford F700 with 16' flat dump cost $2800 so I have $11K in the set just as a reference.
An $11K track hoe could dig faster I am sure but I can move dirt 20 miles much faster with my $11K solution. :D
Actually my real task is moving a hill 1000' up to the house to build a large level pad for a shop. The fill will be as deep as 18' in a few places and I will be doing some filling to cover stumps and other rough places on a hillside so we can make the back yard about 60' deeper into the woods.
Yes most every day I am working the backhoe I think of the things a trackhow would do faster. :)
Adding four chain on FEL forks and the thumb on the hoe means the BH is seeing a lot more hours.
   / Back Hoe -vs- Excavator... Which do you prefer? #48
I use excavator for digging and digging only - there is no better machine for this. I know I should utilize the machine for different purposes but to be honest, the BH does everything else. BH all round, excavator is digging king IMO.
   / Back Hoe -vs- Excavator... Which do you prefer? #49
My vote goes to the mini excavator. I use mine as a crane quite often and the stable base, compact size, and the range of motion allow me to move and place heavy, bulky things with precision. Obviously, a TLB can crane things too, but I use mine in the barn moving equipment around often and I just couldn't do it with the extra size of a TLB. I do have a tractor with a loader to, and really like having them separated as I can dig with the mini and move the pile with the loader. Usually my son drives the tractor, but even by myself it is nice to jump back and forth.
   / Back Hoe -vs- Excavator... Which do you prefer? #50
I want one...!
But here's a thought - has anyone ever used (or even seen) one of these working - definately looks as if it is the perfect match of Backhoe and Excavator (plus telescopic loader) in one machine....
Not sold in USA for some reason, but they sell their other equipment here?
I looked at the specs, only thing I did not like was weak tractive drive force, about 50% if the machine weight.
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
2012 JOHN DEERE 333D SKID STEER (A52706)
2012 JOHN DEERE...
2007 KONECRANE SMV25-1200B STRAIGHT MAST FORKLIFT (A51406)
2007 KONECRANE...
2013 Volvo BL70B (A47477)
2013 Volvo BL70B...
New JMR Mini Skidloader 40" Grapple (A50775)
New JMR Mini...
