Backhoe as Tiller
   / Backhoe as Tiller #1
CompactTractorFan
Super Member
Pennsylvania
Kubota BX25
Can you use a backhoe as a poor-man's tiller??? I'd like to have a small garden next year and I don't think a tiller is in the budget. So, has anyone done this before??? I think I once saw a video of it being done.
   / Backhoe as Tiller #2
You certainly can break loose and turn over the soil with backhoe.
How large is your garden area?
   / Backhoe as Tiller
We don't have a garden yet, but I was thinking about planting pumpkins next year after I read another post on here.
   / Backhoe as Tiller #4
You could certainly make a bunch of little hills with the backhoe and Roundup the areas inbetween the hills. A long ago Mother Earth Mag had you digging trenches with the backhoe. These trenches had brush,sticks,twigs lining the bottom. Tne dirt was then backfilled over the trench. It seemed like alot of work then as it still does now. Put an AD in the local paper and trade a freshly dug hole for the use of a #3 point tiller for a week.
   / Backhoe as Tiller #6
That strikes me as funny-a mega multi mucho thousand dollar backhoe owned by a poor man??? If your conditions are right, level land, reasonably soft soil, etc. have someone qualified drive the tractor and you run the backhoe. Your bucket should be real narrow or have a ripper tooth device for trenching. Kidding aside, shell out a few hundred bucks for a proper tilling device and do it safe and right.
   / Backhoe as Tiller #8
I don't see why you couldn't do it. Both tiller and a backhoe are more or less replacements for a shovel. When you're done, you'll have a very uneven seed bed no matter how good you are. Drag it a few times or use your FEL to level it. Should be just fine.
   / Backhoe as Tiller #9
NO!! Especially the way it's being done in the video. I thought I would see the teeth being used to break up the dirt. Some of the holes he's digging are a few inches, some a foot deep. All he's doing is making a mess for planting.
A backhoe will compress the dirt when you dig. What's left will have chunks of dirt to break up and air pockets under ground which roots don't like. If you don't break it up right away the chunks will harden it will be worse to deal with than hand digging the area.
A backhoe is a glorified shovel but it is not a tiller. A tiller will powder the ground, when you walk across it you will leave 3 or 4 inch deep tracks. The ground is ready to plant without any other work.
I would hand dig a spot for a few pumpkins, find a tiller or get it tilled before dealing with using a back hoe as a tiller.
   / Backhoe as Tiller #10
Why not buy a used walk behind tiller for a few hundred dollars? Wouldn't that make more sense?
2021 Chevrolet Tahoe FL SUV (A48082)
2021 Chevrolet...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
2014 Ford Explorer AWD SUV (A48082)
2014 Ford Explorer...
2012 Big Tex 14GP-24 Gooseneck Trailer (A50860)
2012 Big Tex...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
