Backhoe Bucket Grader Scraper Blade Build
   / Backhoe Bucket Grader Scraper Blade Build #1
SkunkWerX
Platinum Member
Central Maryland
Kioti CK2510H
This is the Bucket Scraper Blade, built for fellow TBN member Ktmpat for his BX24.
It isn't made for any rough use, more for scraping up loose dirt or pulling loose fill back into a trench from the opposite side when it's not convenient to cross the trench. Also for raking up loose rocks and scruff after backfilling.
Requirements were that it needed to be easy/quick to attach and remove. Takes a 3/4" wrench / Socket.
Method: Remove middle tooth, using existing bolts for middle tooth, attach the Scraper Blade.
Dimensions:
Moldboard: 34" x 4" x 1/4"
cutting edge: 3/16" x 2" (mild steel, not a carbon edge)
Backing/rigidity strap: 1/2" x 1/2" bar stock
Not much else to say about it, pretty simplistic.
   / Backhoe Bucket Grader Scraper Blade Build #2
that is a great idea.
   / Backhoe Bucket Grader Scraper Blade Build #3
Yeah, pretty cool idea.
Has he hit anything with the edge to cause it to tweak sideways? I imagine the outer teeth gives it stability? The one tooth attachment is very clever and simple Skunk.
   / Backhoe Bucket Grader Scraper Blade Build #4
Quite nice. I had just been thinking of something very similar the other day. Now I wish my bucket teeth were bolt-ons, not welded.
Thanks Rob.
This one is purely experimental. Just out of the shop, hasn't done any extensive work, yet.
The 2 outer teeth do provide the stability and back support. Best description is that it is "wedged" , with the teeth touching the back spine (the 1/2" x 1/2" barstock).
I too, thought about the torque and stress at the outer edges, hit a big embedded rock , and pull hard enough, and yes, I think the edge will deflect, then bend. For the smaller BX24, it should really be about 24", not 34" , it was just that was the length of the plate I had, so, what the heck? Can always make it shorter once it's used and assessed.
The key is that it is intended for moving loose dirt, loose gravel, sand, but not for digging in virgin soil.
We will report back, once it's been played with ... I mean... umm....used for serious work. ;)
   / Backhoe Bucket Grader Scraper Blade Build #6
   / Backhoe Bucket Grader Scraper Blade Build #7
   / Backhoe Bucket Grader Scraper Blade Build #8
Make one long one, and also I use a short 12" one a lot to dress swails, and work in tight spots. Just a piece of angle on the back of the teeth, and some bolts through the angle and the scraper between the teeth, will work fine. It does not have to be fancy.
   / Backhoe Bucket Grader Scraper Blade Build #10
No bolts at all.
And installation is a snap, uninstalling is even quicker. :rolleyes:
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2018 FREIGHTLINER...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
1994 Generac Olympian 3054 125kVA 3-Phase Diesel Generator (A55851)
1994 Generac...
Ford 8510 (A53317)
Ford 8510 (A53317)
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
2019 WACKER NEUSON LIGHT TOWER (INOPERABLE) (A55745)
2019 WACKER NEUSON...
