Backhoe Bucket Size
   / Backhoe Bucket Size
SO I have a question re: ripping roots. I don;t have a lot of stumps to remove immediately...maybe in the future if I start working for hire....I've never actually used a BH for stump removal. Always have had to dig around with a spade, cut the roots with axe or chainsaw and then pull out with a tractor or pick-up.
If I can't get through the root with the BH bucket, is it not feasible to lift the root out some with the bucket then fire up the chainsaw to finish it off?
   / Backhoe Bucket Size #13
Likely as not, if you can lift it up, you can break it with the back hoe. You could manage OK with a 12" but just have to dig further out so the root isn't as big. I like my 7" because it is much easier to cut thru a root with the smaller bucket and then use the narrow width to get in between stabilizing roots and tap root to remove more of the dirt. I can dig them out with the 12", but it takes longer than using the 7". The 7" is custom made by cutting down an 18" by original owner. I think he found quickly that the 18" was too big for the little B26. My super hard ground with lots of rocks is a chore on the 12" digging with it. Your soil may be much softer, if its any harder if would be a replacement for concrete.
I have very rocky, dry soil as well - so smaller would be better?
   / Backhoe Bucket Size #15
my soil is hard and rocky. I've ripped out many many large stumps with my 12 inch. If I had a smaller bucket, I wouldn't even mount it.
As I said before, the 12 in does about everything I need to do. I very seldom use the bigger one.
   / Backhoe Bucket Size #16
I modified my 5' front loader bucket to fit the BH77 backhoe, I like it 'cause I can take out two stumps at once. Just sayin'
10" and 24" - - thinking about getting an 18" as well, wish the hoe had quick detach for the bucket. Does have a mechanical thumb that I'm going to convert to hydraulic.
bumper :c)
   / Backhoe Bucket Size #17
I have an 18 inch bucket that was taken off and never used has I 1/4 pins I don't need it so if anybody interested private message me thanks
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
2015 Mitsubishi Outlander Sport Multipurpose Vehicle (MPV), VIN # 4A4AP3AU0FE026699 (A56859)
2015 Mitsubishi...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
16ft T/A Flatbed Trailer (A56858)
16ft T/A Flatbed...
