bindian
Super Member
Brandi, I thought about going with 5 dual-teeth, but since the configuration when I bought the TLB was two on the outside and 3 singles, I decided to first try just the dual in the middle and leave two singles. I bought lots of teeth, so I can configure the bucket anyway I want the next time the teeth need replacing based on how I think this works out.
I'm not sure what you mean about the thumb. It seems to me the thumb would work just fine with these teeth. I don't think you have to worry about breaking off a tooth because the teeth are pretty darn strong. I haven't found any roots that these teeth have any problem with either. Of course, if the roots are big enough, they are going to stall the backhoe anyhow, but for normal small roots, this thing is a beast. My backhoe is 92 hp and there isn't much that wins the battle with it.
My bucket is 24" wide, but has 5 teeth. I can see from your pictures that your 24" bucket with only 4 teeth sure has a lot of room between teeth. Because the dual tiger teeth are slightly spread, they would benefit your bucket's digging by covering a wider space, but with intense pressure at the points. I think they will work well.
Finally, I do see a little wear on your teeth, but I think others would agree with me that even your 24" bucket's tooth wear is minimum. If you go to the tiger teeth, hang on to your others because I believe I'd prefer that type of tooth for digging in soft dirt. I even bought some to put on my bucket for a test run to see how they work. There is nothing wrong with the flat tooth for every day digging.
Jim,
When my bucket curls into the stowed position, the two inner teeth clear the thumb by about an 1/2 inch. Make that 3/8 inch with the slop in everything.
I called Romac parts and emailed them my Brandco part numbers today and also sent photos. They are checking to see if the part numbers will cross reference. I may have to take a tooth off and measure the shank.
My Mahinda dealer wants $20.30 for each "stock" tooth and $8.39 for each roll pin.:ashamed: Since reading your post, and seeing you have 5 teeth compared to my 4 teeth on our 24 inch buckets, I am going to check out moving two teeth and installing a 5th tooth.
In hard packed clay, the gaps between the teeth cause a little frustation in digging full buckets at a reasonable pace. This is what is slowing me down, not so much my rounded shoulder teeth.
I want to change it to either to 5 teeth with some or all dual tigers, or install 4 dual tiger teeth and grind down the tiger tooth side that doesn't clear the thumb enough.
Thanks for the input and web address.:thumbsup:
hugs, Brandi
