Backhoe- Build or Buy?
   / Backhoe- Build or Buy? #41
wmgeorge said:
Thank you for your reply and concern, my reference was to John Deere engineers in general, I have a friend who is a retired JD engineer here in Iowa. When I get time I'll ask him what the failure rate is on 3 point top links. I did edit my posting, the ripping force of the 608 bucket is 2,600 lbs at the rated PSI of hydraulic pressure.
As a Caddigger owner you know how they work, the digging pressure is suppose to push down and back against the stabilizers.
How did this work in the real world?
Did you later on make yours hydraulic?? I may make sure I leave room on the valve mount for another spool!!
RE JD, if you get the chance, go to Waterloo, IA and get a JD plant tour.
They make AG tractors there, I am told. I recently got a tour of the combine
factory in E. Moline, IL and it was interesting. They pulled us around the
factory in a train pulled by an X700 mower.
Anyway, my CADDigger 728 weighed only about 900-1000 pounds. Digging
is accomplished only by pinching the dipper stick crowd action against the
machine, secured by the planted outriggers. The unit can not really dig
down, as that would just lift the outriggers out of the dirt. This means that
it is hard to start a hole, but once you get a start, you pull the bkt teeth
against the back of the hole. You need enough counter weight to support
the weight of a full bkt of dirt fully extended. My 2nd engine was so light,
that I needed to buy lead ingots and bolt them on. It was a Tecumseh
10hp. My first motor was a Yamaha 750 4-cyl MC engine....smooth, quiet,
and powerful, but not designed for stationary use. Great ballast, though....
If you attach a homebuilt hoe to a tractor, these issues go away.
I never went to hyd outriggers as I decided to go with a tractor and hoe
attachment instead.
Sharp teeth on the bkt are very important. Those dull cast steel teeth
out there are not so good. I plan to change teeth on my current hoe.
Frankly this is going to be a light duty machine. Planning on an 8 inch bucket, maybe in the future I'll build a 12 inch for it. Primary use is digging sewer lines at the most 3 or 4 ft deep and electric power trench at 18 inches. Maybe digging out a stump or two, thats why I'm really not concerned about tearing my tractor in half. I would rent, but this place is a 2.5 hour tandem trailer pull one way.
The local folks are good old boys, but really not motivated to get things done. You'd think at the end of January with snow on the ground they'd have time to get a price together for me for stubbing out the water and sewer lines from the main. I've been waiting a week.
The plans call for using a plow share (cutting with my plasma cutter) for the teeth or cutting edges, I'm not looking that far ahead yet. Thanks for the help.
   / Backhoe- Build or Buy? #43
Pulling on stumps with a b/h can be the hardest strain on your tractor.
You exert max force, which often gets suddenly released when a root
breaks.
Anyway, my self-propelled CADDigger was a very useful tool. I did several
trenches, and I was able to get it into places I could not even go with a
tractor.
If you have a plasma cutter, don't buy any of the pre-cut steel...cut
your own and save a ton of $.
breaks.
tractor.
And with my recycled metal dealer 1 block away, (this was a farm town) I think cutting the parts myself, I'll have about $350 in the metal fab part and no $300 shipping charge. The hydraulics are another story....
Well I did get the 608 done and it works great!! Worked so well that my son "borrowed" for 3 weeks to dig in his drain field, tile and culvert across his driveway. Oh forgot about digging a 10 foot long, 4 foot deep retaining wall.
Nothing happened to the tractor, the top link did not break, the tractor did not pull apart and he did not die from his head hitting the roll bar! In fact the drivers head can not hit the roll bar even at the highest point the 3 point can raise.
I posted all the details over on the Machine Builders Network so I could put up pictures.
Link > Machine Builders Network
BTW My final cost on the project was about $1,600.
Now my next final touch is to put on a thumb, hoping to be able to move RR ties around for a small landscaping project. Planning on the one from Metkit with the Caddigger, unless some has a better one they would suggest?
   / Backhoe- Build or Buy? #46
Congrats. It sounds like you did a heck of a job and for a great price!!!!!
Thanks for the update,
Eddie
I forgot to add: For my small 16 - 18 HP tractor the 3 point hitch attachment worked slick. All the dire predictions about stress on the tractor... perhaps If I had a larger tractor like most of you have here I'd think about a frame attachment. But this tractor does not generate enough HP to be an issue. IF I was to use it everyday in a commercial environment different story. But no problems.:)
   / Backhoe- Build or Buy? #48
I bought a set of 608 plans last fall. The first week in June I bought a Italian made backhoe instead of building the 608. I am glad to hear it is going well for you. I don't think you will tear anything, tractor or backhoe.
hbaird
   / Backhoe- Build or Buy? #49
Looks good, Bill!
I went to MBN to view your thread. Is the "Super Boom" a Cadplans option
for a bent main boom? First I heard of it.
I found Mikulas' design for the swing cyl pivot to be woefully weak and I
had to buttress it after breaking the welds there. As for his thumb plans,
I emailed about that a couple of years ago before doing my own design and
I could never get a picture from them.
RE your own thumb design: a bent or curved boom may allow you to build
a longer thumb as the clearance betw the dipper end and the boom at full
retraction is a limiting factor.
   / Backhoe- Build or Buy? #50
If you dont build a subframe for your backhoe, i would at least use a semi-4pt mount:
I mean, having 4 point mount on the backhoe frame, and using a triangle to connect the upper 2 points to the top link bracket of the tractor.
This will prevent a lot of rotation of the backhoe when digging besides the tractor. (it gets lateral support on the top link bracket, so it doesnt put as much torsion on the lower link arms)
It will also prevent that the shaft connecting both lift arms inside the 3pt hitch cover to shear off.
If you want it even nicer, you could add a single stabiliser cylinder under aforementioned toplink A-frame to push the tractor off the ground to place the backhoe even firmer on its feet. Then you dont need hydraulic outriggers but just some solid support feet, because you can pick it up with the 3pt lift when the stabiliser cylinder under the triangle toplink, is in float.
this would be the best quick&cheap substitute for a backhoe subframe.
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2011 Komatsu GD655-5 Motor Grader, S/N 55088 C014007, PIN# KMTGD026P01055088, Turbo Diesel Engine, (A59076)
2011 Komatsu...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2007 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2007 Chevrolet...
2007 Pierce Dash Pumper Fire Truck (A55973)
2007 Pierce Dash...
